Compressor
Stan
01-10-2002 15:28:59
Got a 3 gallon gravity feed sand blaster from the wife for Christmas. (maybe shes tring to tell me something)
Now I need a compressor. What should I look for ??? Small shop use. old truck and a couple of tractors that could use some clean up and fix up.
Thanks in advance for any help .
Trucker
01-12-2002 17:42:31
 Re: compressor in reply to Stan, 01-10-2002 15:28:59
If you have a Sams club around where you are you can get one with a 60 gallon tank cheaper than anyplace I've seen yet.Might look in a Harbor Freight catalog,but to run a sandblaster you need a lot of air and one of those portable ones might blast sand but it will run constantly.
John ('48 Cub, Ohio)
01-11-2002 07:16:38
Look at the maximum cfm required by your sandblaster and get one bigger than that by some safety factor that makes you comfortable. It needs to be bigger so that it doesn't run constantly.
JohnP
chris mf-35
01-10-2002 15:51:19
i bought a new one about two at tractor supply,it is a true 220vac 21amp 5 hp it is a three cyc. single stage cast iron puts out 19cfm at 100psi will go to 150 psi. it's yellow 60 gal tank Maxair made in canada. i love it and it cost about half of what all others i looked at with same cfm. it was $599.99 and no tax in some states if used on the farm.
