Honeing Question
fordson29
01-09-2002 15:37:20
Honeing (if thats spelled right) Anyway is there anything that won't clog up the stones?? I have used oil and every other kind of spray and nonspray lube. Am I missing something?? Or can you hone it dry?? I have been taking the hone out and wire brushing them clean. Two seconds later its clogged again. Jonathan
DonB
01-11-2002 13:46:51
 Re: Honeing Question in reply to fordson29, 01-09-2002 15:37:20
For honing oil, I use that half empty bottle of brake fluid without the cap that shows up on my bench after my sons have been around, usually just after I buy a clean new bottle.
Rory
01-10-2002 08:44:46
One thing to think about, when you are 'cleaning' the stone with a wire brush, is that you are depositing the metal from the brush on the stone as well.
Doc
01-09-2002 21:36:34
I use WD-40. The solvents mentioned will work well, just keep a steady stream of whatever lube you choose going. I run the drill with one hand, spray the wd with the other. Doc
george md
01-09-2002 20:47:18
jonathan, Several of the oil companies make honing oil,but as statedin other post fuel or kero work
well . I use solvent , flood the hone and catch and recirculate it . If you flood it well enough
the stones will stay clean , and you will not have the gray slime to clean out ( tough to clean). To
clean , soak with an oily cleaner ( orange label
gunk or the like), then steam clean with a non-
oily soap. we always hot tank before boring and
honing. e mail if you have questions.
george
Greg D.
01-09-2002 17:57:25
I think solvent works real good. You can put it into an oil pump can and squirt it in or just make sure it stays wet while hoening. Don`t think I would do it dry.
Norman
01-09-2002 15:52:19
Ford, I use brake fluid. Just keep it flushed good then clean it after I'm finished. Later
Norman
JMc ...Idaho
01-09-2002 16:45:13
 Re: Re: Honeing Question in reply to Norman, 01-09-2002 15:52:19
When I have honed out brake cylinders on cars I have used alcohol that is what the instructions tell you . I think the reason for that is that alcohol is compatible with brake fluid .You may give this a try .Alcohol may make the metal grindings more liquid. Just a thought, JMc
TB
01-09-2002 16:38:28
Have not done meny but the ones I have been around thay keep them flushed with desel fuel or kerosene.
