Wiring for a mig welder
Ken B in CT
01-09-2002 15:17:48
I want to hook up a 200 amp MIG welder in my garage. What size and type of wire should be used? Also what amp circuit breaker? Thanks.
John - NY
01-10-2002 07:11:10
 Re: wiring for a mig welder in reply to Ken B in CT, 01-09-2002 15:17:48
I run my 200 amp arc welder off a 50 amp breaker with #6 aluminum wire. I believe #8 copper is rated for 50 amps also. If 30 amps is sufficient, the other gentleman's recommendation of #10 copper is correct for that amperage. Of course if you're running longer distances, you'll have to oversize your wire size to compensate for the loss.
Farmer/Paul
01-10-2002 05:29:15
I have a 200 amp Air Liquide mig ( looks like a miller) The plate on mine says 25 amps. I have mine wired in to a 30 amp breaker with 10/3 wire.
BB
01-10-2002 04:36:42
You need to find out what the input requirments are for the welder. There should be a plate on the welder with all the electrical information. Once you know the input amps and voltage, you can size the breaker and wire.
Rod MI
01-09-2002 22:40:28
I have a 50 amp circuit breaker but I don�t now what the wire size is Rod MI
