Arbor bushings
Jim-Ill
01-04-2002 19:39:19
I was going to hook up an old arbor unit, the kind that has a grinding wheel on one side and a wire brush on the other with a pulley in the middle to drive it and realized the bushings were both worn out. Can you buy bushings for these? If so where?
Thanks much.
Jim
Mac
01-05-2002 12:11:48
 Re: arbor bushings in reply to Jim-Ill, 01-04-2002 19:39:19
Bushings of all sizes are pretty easy to obtain.
I usually put a grease fitting on these bushing blocks. One time I did replace the bushings with a pillow block type bearing. Sure worked a lot better and they simply dont wear out when you grease them regularly, not that expensive but you may have to reconfigure the assembly a little.
