Oxy/ac torch
Chrisr MO
12-27-2001 18:56:39
I was referred over here from the 8n board. I need to use a torch that I haven't used since high school. Can somebody refresh my memory on the regulator settings for the oxygen and the acetylene? I am cutting a leaf spring off. Thanks for any help!
tyler
07-30-2003 12:52:08
 Re: oxy/ac torch in reply to Chrisr MO, 12-27-2001 18:56:39
i use 2 on acetylene and 60 on oxygen but i have a large torch that cuts18-22 inch thick steel
Greg
12-28-2001 12:03:38
The settings will depend on the brand and tip size you�re using. What do you have?
Victor, for example, puts out a Oxy-fuel welding, cutting and heating guide. You can probably pick one up at your local dealer or on the web.
Dave
12-28-2001 08:47:08
Mark is right 5 psi ac and 40 oxy. you Sould not go over over 5 psi on the ac. It dose come unstable. And that came from my weld shop instructor .
Mark A
12-28-2001 08:07:58
I use about 5 PSI acetylene, 40 PSI oxygen to cut.
Nolan
12-28-2001 03:28:57
#1 rule, keep the acetylene below 15 psi. Without the acetone in the tank, acetylene becomes progressively unstable at higher line pressures.
Myself, I tend to run around 15-20psi oxygen, 5-10psi acetylene.
Walter
12-27-2001 19:58:47
28 pounds for the Oxygen. 8 pounds for the Acetylene.
Mac
12-28-2001 07:11:39
 Re: Re: oxy/ac torch in reply to Walter, 12-27-2001 19:58:47
I always use 7 acet. and 20-25 oxy.
