Master cylinder for Hyster forklift
Steve Finley
12-26-2001 18:31:18
We have a very old Hyster forklift that we need a master cylinder for. I wondered if there was anyone out there that had a source for parts for old forklifts. I think it was probably made in the late 1950's. I have already tried auto supply stores with no luck. Thank you. Steve
Tom
12-30-2001 06:06:37
 Re: Master cylinder for Hyster forklift in reply to Steve Finley, 12-26-2001 18:31:18
We had a similar vintage fork lift at work and used it dayly until a year or so ago. Always got parts from Ocean State Forklifts Inc. they are at 22 hollister Rd. Seekonk, MA The phone no. is 1-800-698-4630. Worth a call. Have your model no. and serial no. on hand.
Jim K
12-27-2001 07:31:09
Steve I've done alot of forklift repair and a good source for not so expensive parts is UNISOURCE they should have a website I haven't checked yet,but now I'm curious.You could also also try wagner and match the bore and stroke.
Jim K
Gary
12-27-2001 07:29:40
Steve, Depending on what model HYSTER you have, your local dealer might be about to help out. Let me know where you are located and I'll come up with the dealer info. I work for a HYSTER dealer in New Orleans and we have a communication guide that cover the whole country.
At one time, the president of HYSTER was a guy named Steve Finney. Just useless trivia!!
John
12-27-2001 20:28:08
 Re: Re: Master cylinder for Hyster forklift in reply to Gary, 12-27-2001 07:29:40
And Mr. Finney was a great guy.. I was a repair guy who occasionally did Hyster in the Chicago Area
Gary
12-28-2001 09:23:21
 Re: Re: Re: Master cylinder for Hyster forklift in reply to John, 12-27-2001 20:28:08
John,
Ever run across a guy up there by the name of Jim Meurer? He worked there for years under John Latere?? and then moved to beautiful Louisiana.
Unimog
12-26-2001 19:11:00
Steve here's the names and addresses of shops
that rebuild your old unit. They clean and sleeve
them with brass and most give a lifetime warranty.
White Post Restorations in VA, www.whitepost.com
Sierra Specialty Automotive in CA
www.brakecylinder.com
Brake + Equipment Warehouse in MN
www.brakeplace.com
The turn around is usually 7-10 days. The work is
not cheap but thems the brakes I guess. Good
luck.
Unimog
