Compressor CFM
Ray A
12-25-2001 21:12:13
Thanks to Kevin and Jeff- Kevin you spoke of the math. Explain what you mean and illustrate. Thanks Ray A.
Kevin
12-26-2001 16:39:10
 Re: Compressor CFM in reply to Ray A, 12-25-2001 21:12:13
Ray, If you check down a couple of questions on this board regarding air compressor motors, you will find Rogers excellent description of finding the volume of your piston and bore. You then would need your Piston RPM, and CFM is right around the corner!
