Welding Rods
Hanovertom
12-24-2001 16:41:51
Does anyone have a source or idea where you can get a chart that list welding rods and thier properties, heat etc. to help guide us novices
tom Link
hanovertom
12-25-2001 17:21:49
 Re: Welding Rods in reply to Hanovertom, 12-24-2001 16:41:51
Thanks for the help. Merry Christmas and Happy new year to ALL!!!
Russ
12-25-2001 12:10:55
Hi Tom, Greg did a pretty good job of covering potential suppliers. I just want to add my two cents. Aside from going to any weld supplier who sells in 50# cans, just kind of a thumb rule to seperate the real suppliers from farm stores and the like, You should try the web sites for Lincoln Electric and look for the "Stick Electrode Welding Guide" which was free last time I checked, The Hobart electrode site which offers all kinds of free tech data sheets and a nice wall poster of the info you want, think I had to email tech support with a request for info for that, and Uniweld for their alloys manual, also free. I have found that if you contact the manufacturer directly, they are usually very happy and anxious to give you this information and will even give you free small samples of different rods to try. Believe it or not, all the different manufacturers of a particular AWS spec rod such as 7018 all believe their rod is supperior for one reason or another, and they want you to try it. There are often subclassifications within the AWS specs also and they want you to be able to pick the best rod for your application and then become a loyal customer. I have made inquiries to all the major companies and have always been rewarded with contact with people who are eager to please it seems. Of all the different manufacturers reps I have dealt with, the weldors reps have been the best. Russ
Greg
12-25-2001 09:49:51
Hi Tom,
This is one of the [better] questions, that most/some of the self taught welders who have been welding for some time don�t seek or know that this kind of knowledge is available.
A local welding supply store should have some of these types of manuals [Welding Guide, Pocket Welding Guide, Selection Guide, Filler Metals, Cross Reference Chart, etc.]. A lot of the time they are given free or at a minimal charge. Also sometimes when I purchase Electrodes or Filler Metal I�ll ask for what I�ll call a parameter [sp?] sheet [for lack of a better term], which they will often times run off on a copy from their book on a copy machine for me.
On-Line you may want to look for these under such heading as, books, filler metals, electrodes, technical / manuals, training, etc.
A few sites of many are.
Link
Link
Link
Link
HTH & A Merry Christmas to all.
oldjohndeere
12-25-2001 09:25:43
You should be able to get one from a welding supply store. If not, how about a high school shop class or tech school welding class.
Bubby
12-25-2001 17:32:09
 Re: Re: Welding Rods in reply to oldjohndeere, 12-25-2001 09:25:43
If you are a novice welder (work as welder only occasionaly)buy a box of i/8 " E-6011 and become proficent with it. When you can make 100% welds with it the weld will be stronger than a poor weld with the rod which is technically right for the job. Have welded
since 1958 taught welding 12 years and ran welding shop 14 years. Still have only 6011 in my retirement shop at home
