Used oil burner
koop
12-24-2001 10:07:03
i would like to build a user oil burner from an existing wood burner need to know the type of pump and nozzle to use any suggestions would be helpful
Cliff Neubauer
12-25-2001 07:11:38
 Re: used oil burner in reply to koop, 12-24-2001 10:07:03
I burn oil in our wood stove by dripping the oil on the fire, once the oil gets going it will burn very hot and a couple small logs will burn all day. I used an old #100 lp tank for my oil tank, stood it upside down and brazed a 2" pipe nipple in the top with a screw on cap. I still use the original lp valve to regulate the oil flow. If you want send me an email and I'll send you some pictures.
lemennais
01-24-2003 06:59:48
 Re: Re: used oil burner in reply to Cliff Neubauer, 12-25-2001 07:11:38
Thank you for your pictures
Steve from Tn
12-24-2001 13:53:22
Hey Koop, a friend put a 50 gal. drum up on the wall about 6 feet and well away from his stove. His stove is a barrel stove. He ran a pipe into the small bung hole in his supply barrel with a 3/4" gate valve. He then ran the pipe into the top of his stove.(I think he drilled a hole and just ran the pipe through. He adjusts the oil flow according to heating need. He uses wood in his stove in conjunction with the oil. It works really well. Don't forget to turn the oil off when you leave the shop. Good luck.
Redtractorman
12-24-2001 18:57:19
 Re: Re: used oil burner in reply to Steve from Tn , 12-24-2001 13:53:22
Sory about that I left the link out.
Heres free plans to make one.
http://journeytoforever.org/biofuel_library/ethanol_motherearth/me4.html
Redtractorman
12-24-2001 18:56:27
