Drill press chuck
kevin
12-21-2001 19:22:55
I have a Duracraft drill press mod.SP30, serial no. 218175. I need a chuck for it but I cant figure out what taper the spindle is. How can I find out what size chuck to get.. I dont have the old chuck. Thanks for any help!!
gene b
12-25-2001 04:24:04
 Re: drill press chuck in reply to kevin, 12-21-2001 19:22:55
your supposed to put the key in the cjuck and wack it with a hammer it should screw right off
John in MA
12-27-2001 18:10:20
 Re: Re: drill press chuck in reply to gene b, 12-25-2001 04:24:04
Drill press chucks don't unscrew. They use tapers.
gene b
12-28-2001 03:25:56
 Re: Re: Re: drill press chuck in reply to John in MA, 12-27-2001 18:10:20
now you are trying to give an old machinist a bad time how many do you want I have some threaded taper ones and there are some that have a taper on both ends some screw on to the taper with a allen cap screw any how it will come off
John in MA
12-22-2001 15:38:21
What kind of drill press is this? Most imported benchtop and some floor standing models have a Jacobs 33 taper machined onto the end of the spindle.
It definitly has a JT33 if it's one of those 8" benchtop imports.
norbert kanzler
12-21-2001 21:37:41
try a number 2 moris taper you can most likely get one from local hardware store or borrow one to try
Ray,IN
12-21-2001 20:05:06
I had an old press once that the chuck went bad on and I just phoned the LOCAL hardware store with the information I had on the press and they ordered one for it. Most of the tapers are a standard size, you can measure the taper angle and length then refer to Machinerys Handbook for details if you wish.
C.George
12-22-2001 05:13:35
 Re: Re: drill press chuck in reply to Ray,IN, 12-21-2001 20:05:06
Kevin , If you like, you could give this website a look, Link you may get some good advice/help there ,if not here
