Grinder
jim
12-18-2001 23:59:21
My 8" craftsman bench grinder will not get up to operating speed, it turns very slooow. Is it possibly the start capacitor?
Mac
12-19-2001 12:49:49
 Re: grinder in reply to jim, 12-18-2001 23:59:21
Been a long time but maybe you fellows can come up with what I am talking about, Seems some motors have a so called "spoon" on a non capicitor motor. Onback end of the shaft. Motor starts on a start winding and then throws into a run winding. I have seen these break and cause no contact for the run winding. I used to know this stuff about 50 years ago?? Like the other poster states tho, if you can turn it fast enough by hand and turn it on it should run the specified RPM's. Hope I didnt confuse you fine fella's.
Thurlow
12-19-2001 04:12:39
Jim, before you turn it on, grasp it with your hand and give it a yank, i.e., get it to spinning as quickly as you can. Quickly turn it on; if it's the starting capacitor, it should catch up and run.
Bigdog
12-19-2001 01:37:11
If the shaft is turning freely when the motor is off, the start capacitor is probably bad. (assuming you have a capacitor start motor) But check to make sure the bearings / bushings are not seizing up.
