Air Compressor
Hanovertom
12-18-2001 18:01:28
I have an older Saylor-beale air comp that had a 3HP 1725 rpm motor with a 5.25in dia pully. Can I calculate for a smaller pully and use a 3450 rpm motor of a lower HP
Tom
Neil
12-19-2001 20:28:29
 Re: Air Compressor in reply to Hanovertom, 12-18-2001 18:01:28
You can run a compressor slower within a range.
If you get a splash lubricated compressor running too slow it will not get enough oild on the cylinder walls.
If you can find a manual or spec sheet on the pump it will have min and max speeds, and usually speed for different HP.
John in MA
12-19-2001 07:59:55
Work is work--you'll need to turn the compressor slower if you use a less powerful motor. 3450 is twice the speed of the other motor, so you'd use a sheave half the diameter to keep the driven compressor's speed the same. What you want to do is lower the compressor's speed to the point where the motor reaches max current draw as the pressure switch kicks off.
I turn a biggish single cylinder compressor with a 1/2 HP motor. Only catch is the compressor is at 460 RPM.
T_Bone
12-18-2001 19:46:49
If the motor is correct for HP,RPM and pulley for a given compressor, then no, as amp draw will be more than the new RPM or HP requirement.
You can change to a larger diameter pulley with 3450rpm with more HP.
T_Bone
