Cleaner solvent
Don from Texas
12-17-2001 18:39:16
Bought myself a parts cleaner from TSC ,want to use it but dont`t want to blow myself up. what solvent should I use?
Mr. Clean
12-18-2001 23:59:50
 Re: cleaner solvent in reply to Don from Texas, 12-17-2001 18:39:16
Low Odor Mineral Spirits, and wear some rubber gloves when ya can to protect yer paws.
Don from Texas
12-19-2001 18:57:01
 Re: Re: cleaner solvent in reply to Mr. Clean, 12-18-2001 23:59:50
Thanks Fellows,appreciate the advice.Will go with it.
max
12-18-2001 12:50:57
what is varsol, and how expensive?
Kelvin
12-18-2001 18:24:54
 Re: Re: cleaner solvent in reply to max, 12-18-2001 12:50:57
Varsol is a trade name for mineral spirits.
ROD WILSON
12-18-2001 07:59:59
MINERAL SPIRITS. WORKS GREAT, AND ITS INEXPENSIVE.
DavidO
12-18-2001 07:40:02
I have been using one part carb cleaner to four parts kerosene in mine for about 30 years. I guess it is old fashioned and not enviromentally correct, but it was what was recommended by the parts washer maker when I bought it and it has worked well for me since. Only problem is when it needs flushing, getting rid of the old stuff.
buck
12-17-2001 20:50:54
have used varsol in mine for about 25 years. Many service stations and hardware stores carry it. Was originally recommended to me by a safety-clean man.
Ray,IN
12-17-2001 19:53:05
There are a number of good water based solvents on the market now, phone the local NAPA, or other chain type stores and ask what they use. If you want a petroleum based solvent, Stanisol made by Standard Oil is a really good one; similar to kerosene+additives. There again you should inquire at the repair shops to what they use.
