Which way is up? Air Comp. Question
Pigster
12-06-2001 19:52:35
Cleaning up older air compressor that I picked up at an auction. It has four pistons that run off of a camshaft that rides in two cup shaped bushings. Problem is that each bushing has a small square shaped notch on the open end and directly opposite but in maybe 1/8"-1/4" there is a small hole. Unfortunately I didn't notice this until I had lifted the assembly from the housing so now I'm clueless as to the proper orientation of the bushings in the housing. The bottom half of the housing has a small groove where the bushing sits - I think to return oil to the resevoir. Can anybody give me their thoughts on how to put this thing back together correctly? Thanks a million!!
