Welding Vertical
JohnInVA
01-07-1999 10:37:33
The welding thread made me remember this.
All you have to do to weld vertical is "cheat" a little.
Using the 6011 Lincoln rod and the buzz boz or better machine, just weld down instead of up.
It works, try it. The 6011 can burn through the flux should it get in the way (sometimes the flux will "run down" in front of the weld).
Fluxes on rods such as 7018, and 7014 rods makes this process a little harder to do, but, I have still done it with those rods.
We are not welding nuclear submarines here, I know the weld "might" not be perfect. I saw a guy pass a Navy Cert. test using 6011, welding vert. down and NEVER chipped the flux til he was done. So it can be done.
Try it you will be impressed with your welding ability!!
John
welder
01-08-1999 18:15:10
 Re: Welding Vertical in reply to JohnInVA, 01-07-1999 10:37:33
7018 is not ever to be used down it is a all position rod but only vertcal up
Hankster
01-12-1999 20:08:38
 Re: Re: Welding Vertical in reply to welder, 01-08-1999 18:15:10
E7018 most definitely can be used to weld vertical down! Done lots of it on jobs that required 100% x-ray.
