Need to remove main front seal on 1961 MF 35
Beverly Carter
02-28-1998 17:46:32
My folks need to find out how to remove the main front
seal from out 1961 Massey Ferguson 35 tractor.
It is leaking transmission fluid that is getting
on the starter. Any info would be appreciated!!
Thanks
Chris
03-10-1998 21:09:16
 Re: Need to remove main front seal on 1961 MF 35 in reply to Beverly Carter, 02-28-1998 17:46:32
: My folks need to find out how to remove the main front
: seal from out 1961 Massey Ferguson 35 tractor.
: It is leaking transmission fluid that is getting
: on the starter. Any info would be appreciated!!
: Thanks
Beverly, To replace that seal you need to split the tractor at the bell housing. Once that is done you can drive a screwdiver under the seal to collapse it. Behind the seal is a bearing which should be checked because that may have caused the seal to go bad. If you have to do this i would also change the clutch, pressure plate and throw out bearing. Email me if you need more help! Chris
