Home-made lumber mill
cj
12-05-2001 09:14:45
Has anybody ever set about building their own lumber mill. I am interested in building one more for messing around in the back yard than anything. I know that the modern units use bandsaw style setups, but could an old chordwood saw with a bigger blade be used to make lumber, or is the bandsaw the way to go? Granted the bandsaw would be way mor efficent, yet the big round blade would be way more fun to run with an old tractor. What would it take to build a simple carriage setup? Any ideas would be great.
Gary
01-24-2002 19:17:02
 Re: home-made lumber mill in reply to cj, 12-05-2001 09:14:45
Any body need mill plans i got em ill e them to you. Thanks
Steve
02-16-2004 05:46:23
 Re: Re: home-made lumber mill in reply to Gary, 01-24-2002 19:17:02
I'd love the plans if still available. Thank you.Steve
laphil
02-09-2005 10:53:22
 Re: Re: Re: home-made lumber mill in reply to Steve, 02-16-2004 05:46:23
we would like a copy of the sawmill plans as well if still available pls and thanks
Dave
08-24-2003 07:55:21
I'd love the plans if they are still available. Planning on building one sometime in the next couple yrs so would appreciate any help. Thx
wrenchman
12-19-2001 23:34:12
here's a pretty good outfit & they give good service too. Link
EddieV
12-09-2001 12:19:21
Search the web. There are many, many companies out there that make parts to build your own all the way up to a complete mill. As far as circular or bandsaw, you'll find people who are dedicated to one type or another as you'll find those who are partial to Ford, Chevy, Farmall or John Deere. I personally like a smoother cut and a little less waste that most bandsaw mills provide. If you find you are going through many blades, the problem may be how your cutting. I've worked with a friend putting many board feet of lumber through his Woodmizer. It is a very good quality machine. I'm sure there are others out there just as well. I just haven't worked or used them.
B.Smith
12-06-2001 20:26:28
CJ
Lindsy publishing has a set of plans for a circular blade mill, it's kind of like a book on how the builder of the mill went about building it with lots of pictures and text on how it is built and what type of parts he used, I think it is less than $25.00 for the book.
Check out there web site they have lot's interesting projects a man can build.
Bob Smith
Thurlow
12-06-2001 08:18:24
cj, Sawmill & Woodlot Management magazine (www.sawmillmag.com) has pretty much any information you would need about sawmills.
Grove r
12-06-2001 06:51:30
Hi, CJ, have built my own 'mill several years ago, still use it, by myself mostly, doesn't take a lot of repair, or money to keep it going, use a forklift to move logs from the stump to the mill. this is a 48" circular head saw type, with "hard" teeth. Two of my neighbors had the band saw type mills, and both agree that the biggest expense with them are the band saw blades. Not saying every one is the same, but these particular ones used a lot of blades. The one fellow [comercial], was buying his blades in bulk, now uses a circular sawmill.
There are several different ways to build a mill; one I ran accros last summer really caught my eye, this was a circular saw, 18"?, attached to the crankshaft of an eight HP air cooled motor, that was moved down a track by a hand crank. The log was "dogged" to three head blocks, and was moved manualy up to the saw for each cut. This would be great for small logs, could probably cut up to eight inch wide lumber, if done correctly. Depending on the size of the saw and HP of the motor, one could saw some decent size timber, length dependant on the lenght of the track. Might be a bit time consuming, but time used against price of lumber, still leaves a lot for other expenses.
Hope this is of some help, if you want more info drop a note here and I will e-mail you. Have a gooder, R.E.L.
Gary
07-04-2003 11:38:46
 Re: Re: home-made lumber mill in reply to Grove r, 12-06-2001 06:51:30
Grove r i saw your post on sawmills and i am interested in the info on the circle saw mill that works off the crank of a engine that you posted a while back[2 years]. Thanks
PCC-AL
12-06-2001 02:09:59
Hi cj,
During my lifetime, we have had several small sawmills set up on our place when the trees needed to be cut. This was in the early days.
The old round saw mills wasted a lot of wood and needed a lot of repair. The first ones used mules to drag the logs up. Later ones used skidders. Either wasy, the operation required a lot of manpower and was inefficient.
When hurricane Opal hit, a lot of timber was put on the ground. Professional loggers salvaged some and left a lot. A local guy has a one man band saw mill and agreed to saw for half the lumber. I was able to get a local mill to plane it for me.
Even with the band saw mill, about four of us were required to keep the operation moving.
I rambled too long to make my point. Producing your own finished lumber from trees requires lots of money, time and manpower. Above all, be careful, they like hands, fingers, etc.
Good luck.
Gary Johnson
12-05-2001 18:10:02
My uncle in the early 1960's set up just such a sawmill in southern Minnesota. He used it to saw red oak from his property into the siding, rafters, and uprights to build an addition to his milking barn. I too wish I had his experience to draw on, and how he set up the mill. I know he got the saw from a neighbor and ran it from his International model H tractor. There was a framework that bolted onto the tractor front holding the saw, but I don't know if the ogs were fed in from the front or rear, and I have no idea what he used for setting the thickness of the board. I have a JD that has a pulley drive on it, and a circular saw that I have been thinking of setting up in just the way you are talking about. If you get the drawings oor a source for them, email me please.
F14
12-05-2001 10:04:50
Bandsaw is the way to go. Takes less power to run, safer, wastes less lumber. I've got a set of plans for one that I bought from a feller in Farm Show magazine, I'd be willing to let you have 'em cheap. She Who Must Be Obeyed shot down the idea...
cj
12-05-2001 12:48:44
 Re: Re: home-made lumber mill in reply to F14, 12-05-2001 10:04:50
I am located in central ct - how about you??
I would be interested in such a setup at the right price, but getting them home could be a problem if you are a long distance away. More details would be great.
cj
12-05-2001 12:50:12
 Re: Re: Re: home-made lumber mill in reply to cj, 12-05-2001 12:48:44
Disregard that last message - I read too quickly and though you had a "planer" for making lumber. I would still be interested in theplans though.
F14
12-05-2001 13:30:54
 Re: Re: Re: Re: home-made lumber mill in reply to cj, 12-05-2001 12:50:12
Check your email....
