Welder
Jim
12-02-2001 07:03:00
What kind of welder should I get. The only time in my life I welded was in high school, 50 years ago, on an arc welder. I was thinking maybe of a Lincoln 225AC or would I be better off with a torch outfit. That would have come in handy around here on many occasions. Is it hard to learn on one of these? Also what is the deal on the tanks. Someone mentioned that these are rented. Is this always the case? Thanks much for your input. Jim
TRUCKER
12-07-2001 17:51:34
 Re: welder in reply to Jim, 12-02-2001 07:03:00
The best welder to start with is a buzz box,like a Lincoln 225.It depends what you need to weld though.If you want a lot of strength and on thick metal a buzz box is best for somebody that doesnt know how to weld,then you will need a torch.Find a place that distributes bottles to welding shops and I bet they would have a used torch maybe.You can weld stuff with a torch,but it isnt as strong as if you weld it with say 7028 electrodes on a buzz box.you can weld thin metal with a torch and a piece of baling wire.With just a little bit of help from somebody that can weld you can learn how to do both of these things in about an hour.After that its mostly practice and experience.You can go buy one of those 115 volt migs,but if you dont know what you are doing you wont like it.You need to learn just what it is you are doing first when you are welding,and then a mig wont be as hard.The way I look at it though unless you get a good mig you are wasting your time.So unless you can find one at an auction cheap,its going to cost around a thousand dollars for a good 220 volt mig that will last a while,and it is mostly suited for thin metal like bodywork and stuff,and you have to buy gas for it too,and wire.A buzz box,a box of rods,a helmet,and a torch,all together probobly would cost less than 800 dollars including the tanks,if you have to buy them.
John ('48 Cub), Ohio
12-04-2001 04:27:08
I agree that you'll probably want both gas and some kind of arc welder. The choice of arc welder depends a lot on what you will be welding and how often you will be using it, as others have posted. Also, the torch is useful for a whole lot more than just welding. If you can break loose just a couple stuck bolts with heat each year (instead of grinding them off) it's worth having the torch in your shop/garage).
JohnP
T_Bone
12-02-2001 19:03:23
Hi Jim,
If your not going to alot of welding, less than 50lbs of welding rod a year, then I would look at the Lincoln AC/DC buzz box as it's called. Hard to beat for the price and has been around for ever. It has a good stable arc.
A Huntsman 411P welding hood is really nice. A "glass" gold cool-ray welding lens, shade 10 is really the best. Use one clear glass lens on either side of the Cool-Ray lens to protect it as it is a true GOLD covering.
Plastic welding lens will give you two weld puddles to choose from while welding because of distortion.
I would also get a Victor 100 cutting torch. 15ft of 3/16" hose and 50ft of 1/4" gas hose. The smaller 3/16" gas hose will let you control the cutting head alot better.
The next thing I would do is take a Voc-tech welding course so you don't become flustered with learning again. They also will teach torch cutting at the same time.
Every state has different regulations on gas cylinders. Colorado I had a title to my bottles. Arizona you buy them then exchange them when empty.
All the above can be had for under $1000 with acc.
T_Bone
Franz
12-02-2001 17:58:34
I started out with a torch outfit, 40 years ago, then bought a lincoln 225 AC. I haven't quit buying machines since. I own 12 machines today.
If you have nothing, a torch will get you by and get you going till you can afford to buy an arc machine. You'l also have to learn to weld, and that ain't a bad thing. When you do get an arc machine, you'll have an idea what you are doing.
Wait till you know what welding is about before getting a MIG machine. There are entirely too damn many halfassed 110 volt MIG machines being sold to dam fools in today's world, by empty headed twitts in discount stores. It's gotten to the point where every halfwitt in suburbia has one of the damn things, and thinks he's a weldOr. Please NOTE the spelling, a welder is a machine, and a weldOr is a person who can run the machine.
Whatever you buy, get it from a reputable welding supplier, not some dipshut discount store, because you are in need of one he11 of a lot more help than you are ever going to get off any web site, or video. Go take classes, and learn. Even if the teacher ain't much, you'll learn something.
In case you think I'm on a rant here, consider I watched a trailer hitch break off a truck last Thurdsay, as the fool was towing a 20 foot enclosed trailer. That idiot had "welded" a weight distribution head to the bar with his 110 volt mig machine, and was real proud of his work.
He was also proud he was self taught.
Mr. J
12-02-2001 13:46:32
In my opinion, the MIG welder is the easiest and best quality of welder to purchase. You can weld steel as well as aluminum with a switch of wires. I am an agriculture teacher in SW Missouri, and we are starting welding classes Tuesday night. All of the farmers from the community come in to work on their welding skills as well as fix up and repair anything around the farm that needs to be. You can get 120V MIG units from just about any major tool catalog, as well as Wal-Mart, I think Wal-Mart finally started carrying MIG Welders. And, I haven't had any problems with the MIG welders yet, they use a mixture of Argon and CO2 to shield the weld from impurities, the quality is amazing. It is much easier to weld on sheetmetal with a MIG welder than a Stick welder, and welding with a torch outfit is a highly skilled trade which takes a well trained hand in my opinion. Just my 2 cents worth, but I hope it helps. Whichever way you go, I would at least take the time to test your various options. GOOD LUCK!
TP from Central PA
12-02-2001 11:54:16
I would get both if I was you, once you get a torch you won't want to give it up, same with the Arc welder, nice to have when you need 'em.
F14
12-02-2001 10:16:43
I think you'd be happiest with one of each: Arc welder and torch set. I know I sure wouldn't give up MY torch, but by the same token, I wouldn't want to try to do all my welding with it either.
We rent/lease tanks in Maine, and just swap and empty for a full at the depot. That way, you don't have to fuss with hydro tests, etc. You can get a pretty good deal on a 5 year lease.
Redtractorman
12-02-2001 08:12:44
An arc welder is very handy and easy to use,so if you used it once you could teach yourself again.
A torch outfit is nice for cutting and welding and heating.This does take a lot more practice but can be self taught.Many Vocational schools run night classes in welding and torches.
I bought my own tanks,I think in some areas you do rent them.
SHANNON
12-02-2001 20:12:16
 Re: Re: welder in reply to Redtractorman, 12-02-2001 08:12:44
AN AC WELDER IS NICE BUT I WOULD TRY FOR AN AC/DC WELDER BECAUSE OF THE VERSATILITY WITH ALL TYPES OF RODS INCLUDING 7018 HIGH STRENGTH WHICH IS NECESSARY FOR APPLICATIONS LIKE TRAILER HITCHES AND DEVICES WHERE LOW STRENGTH COULD BE HAZARDOUS!! YOUR TORCH CHOICE IS MANDATORY BECAUSE YOU NEED THAT TO HEAT,BEND,AND CUT METAL.IF USING FOR WELDING,USE LITTLE AS POSSIBLE BECAUSE THE GAS CAN GET MORE EXPENSIVE THAN WELDING RODS. TANKS MOST GENERALLY CAN BE BOUGHT (WITH TITLES)OR RENTED.
