Angle grinders
dc
11-28-2001 19:23:47
I am looking at angle grinders and I am told that you want the high speed of the small ones (4-1/2"). I am a little leary of the ability of the small ones to do a job on heavy jobs. I am looking to use it for cleaning metal for mig welding (hobby basis) and for rust removal on future tractor restorations. Could I have some examples, opinions, sizes? Thanks in advance.
Terry
12-03-2001 19:19:14
 Re: angle grinders in reply to dc, 11-28-2001 19:23:47
You can brag all you want about those expensive grinders but i bought a Craftsman 4 1/2 inch about 20 years ago and its still going strong. God knows is hasn`t had an easy life. I`ve used grinding wheels and wire brushes both and the cord looks like its been run over by a lawn mower.Its never had anything done to it not even brushes. I can only hope the next one i buy will be half as good.
JK-NY
12-01-2001 08:48:25
I would start out with a 4>5 " size one, buy a decent quality one and see if it does everything you need. If you do a lot of large scale welding and fabricating you'll probably need a bigger one too but either way the 4.5 will be handy and get used most of the time.At least thats been my my experience
signman
12-01-2001 05:03:57
Metabo 4.5" all the way. reverse air flow so you don't erode the windings from dirty cooling air. Break away clutch for safety. Helical cut gearing that gives you more efficient power transfer. And the unique quick change wheel feature that allows you to go from grinder to slicer in seconds without fumbling under the bench looking for that darn special wrench. We have 2 of these and love them. About twice a year I get the "horse" 9" IR down for heavy stuff. I mean thigs 1/2" thich or more. Check out Buzzard Gulch or a Fastenal distributor. They have far better prices. ussually in the $115 - $145 range. German tool that will last.
GPWT
11-30-2001 09:48:38
I own and use a 9" Milwaukee and a 4.5" Milwaukee (the 9" for 10+ years) and have been well pleased with them. I would start with the 4.5", it may do everything that you need.
Scott Green
11-30-2001 04:56:17
4-1/2" Metabo
Ray
11-29-2001 18:41:50
Good comments. I just got a 4.5 inch model for 39.95. A 6 amp Skil brand from Walmart. I had a 5 amp and that didn't have enough power for me. What I have noticed (after cutting 60 feet of sheet metal off a pole barn) is that the switch is very important. I would like to have a better lock when in the off position, so you don't accidently hit it and have it crawl up your leg. I like the dead man switch concept. Stay away from those $20 Tool Shop brand models.
Ray
Wayne Woods
11-29-2001 15:36:30
I'll pitch my 2 cents in for the smaller ones, 4.5". I also have a big 7" or 7.5' job, but like others have said, it's heavy, and best for those jobs where you need to really hog some metal off. The smaller ones are easy enough to handle that in tight places I can do it with one hand. Got my Black and Decker from their store that also has repair facilities. Got a great bargain. About $40. Seemed so cheep I thought it must have bronze bushing bearings. The guy looked it up and said it had roller bearings! Sometimes they also have re-conditioned stuff at great prices and good warranties. My big grinder is a reconditioned one, and it's still going strong. If you've got one of their repair storea in your area, check 'em out.
WW
fred lysgaard
11-30-2001 01:18:23
 Re: Re: angle grinders in reply to Wayne Woods, 11-29-2001 15:36:30
i own a master mechanic 4.5" angle grinder 5.5 amp 12000 rpm ive had it for 10 yrs now and it,s been a good grinder for what i use it for i wouldn,t be afraid to buy another one i haven,t had to fix it just buy grind wheels.
bbott
11-29-2001 13:18:46
I have angle grinders in 4.5", 5", and 7" sizes.
If I had to have JUST ONE... I'd take the 125mm Makita (5") as the best.
I think it's the right balance between being easy to manage and big enough to do a good job.
Of course, the best setup is to have all three sizes and pick the right one for the particular job at hand.
All this is IMHO stuff.
bb
John - NY
11-29-2001 12:22:32
I've got a 9" Makita grinder which really does a great job on serious grinding, but it's really heavy and hard to manage over long periods. It's also too big to use in tight spots. I also have a 4�" Clarke from Quality Farm & Home. It has held up really well -I replaced the brushes once.
I did buy one of those $10 specials once - lasted about 1 minute before the casting in the head broke. Hated to throw it out 'cause it looked so good. Lesson learned. Good thing they threw in a few extra grinding wheels. Made me feel a little better! Oh well!!
DumOleBob
11-29-2001 10:30:08
The "bigger" grinders like my 7" Dewalt will sure do some mean grinding, but boy are they heavy & hard to accurately control. Too heavy for anything but short jobs, where you've gotta move a lot of material � for that they a super!.
I have three 4.5� grinders: 2 DeWalts & 1 Milwaukee. They each do a fine job, but the higher the Amps the more power each has. It's all (well, mostly all) in the Amps. Each Mfg make a several different models so watch out for the amp rating & get the most amps for the $. The location of the switch & how you will use it is worth looking at. I like a �deadman� which cuts off if you drop it. Otherwise it may be wrapping around your leg � or worse! Come to think of it you make hang up a wire brush in the belly of your shirt like I've done - in which case the deaman sure is nice! My very favorite is a 4� Ingersoll-Rand (air) grinder. It�s light, very fast, very easy to control & for some reason (probably RPMs) it accurately moves a lot of material. It makes me feel � ARTISTIC! I love it!
I also have a $19.00 Harbor Fgt 4� grinder that isn�t really all that bad, but I wouldn�t want it to be my only grinder. It makes a ton of really ugly sounding rattles � like it�s gonna die, but I've had it three years. If you get a good grinder you may want to put up $19 for a cheap one & put a wire brush on it! When it dies order another, and then another. If you live to be 100 you�ll still not have paid as much as you would have for a super class Milwaukee!
You're not talkin' brain surgery here so just go with a name brand 4 or 4.5� & you�ll live happily ever after. Oh, do wear good eye protection NO MATTER WHAT!
Neal in NM
11-29-2001 08:47:14
By far the best one I have used is the Makita. Stay away from the Harborfreight specials they feel unbalanced and you end up fighting the grinder to keep it in place.
BFO
11-29-2001 05:01:50
I've had the best service from my Metabo (Walter) grinders. Very powerful. The other grinders I have that get used less often are Ryobi, B&D, Craftsman, and Makita. The Ryobi, although less comfortable than the Metabos, is very powerful too. Also, with a wire cup brush on a 4 1/2" grinder, you'll get into tighter spaces than the larger grinders.
TP from Central PA
11-29-2001 16:26:57
 Re: Re: angle grinders in reply to BFO, 11-29-2001 05:01:50
I would buy a Metabo, they are expensive but have excellent motors and gear boxes in them.
T_Bone
11-28-2001 20:06:14
The best one for light duty is a Makita 5". They run at 10,000rpm. If you don't push them I have two about 15yrs old. I also use a 6" cutoff wheel for cutting SS.
I also have a Milwaukee 4.5" and it's just to light and small in size for general use. Now my 7.5" is a work hog but is also heavy but for big grinding jobs it the cats meow.
T_Bone
