Engine won't idle
Bill
11-27-2001 18:41:57
I have a Tecumseh engine, model VM100-157028C, that won't idle. Runs fine at top end, as a matter of fact it seems to run too fast. Sort of like a two cycle chain saw or tiller motor just before it runs out of gas. Open to any and all suggestions.
Thanks..
Bill
Branden
11-29-2001 10:40:46
 Re: Engine won't idle in reply to Bill, 11-27-2001 18:41:57
Sounds like something fairly simple. Could be a few things here,
1. Dirt in your carburetor. 2. Carb out of adjustment. 3. Or more than likely you have a leaky gasket somewhere in the fuel system. Say around the intake gasket, or the carb gasket. If you have had a back fire recently check those areas first. 4. You might also check the throttle shaft for wear and the casting for wear. This might be letting air in as well.
Let me know what you find out.
Branden
