Paint Removal
John
01-06-1999 11:27:30
Hi Guys, I'd like to remove old paint from the woodwork in my house, and am looking for suggestions. More than likely the original base coat of paint contains lead, and this is one of the reasons I want to remove it. I have thought of sandblasting it in place and sanding, or removing it and then sandblasting it, sanding, and then replacing. If this is not feasible, I will more than likely remove it and replace with new. I have a good full-face filter mask, and plan on sealing-off the rooms to be done. One other option is to use a blasting cabinet, but they are not long enough to handle the 6' door and door trim pieces. What do y'all think? Thanks.
Wild Bill
01-06-1999 20:38:39
 Re: Paint Removal in reply to John, 01-06-1999 11:27:30
I would say don't do it. I sandblasted a small piece of furniture outside once, it took of the paint ok but it roughed up the wood beyond resonable sanding. If your concerned about the lead, I think it is safer where it is than being blasted all over the room, you will have sand, paint, lead, wood ect. all over the place. If you want to get to bare wood, remove it , take it outside and use a chemical stripper. DON'T use this stuff inside, the fumes can kill you. I have heard of heat guns for stripping paint but I've never used one. My 2 cents. Good luck.
Mike
01-07-1999 14:53:17
 Re: Re: Paint Removal in reply to Wild Bill, 01-06-1999 20:38:39
Call your local hardware store and ask if they have one of the new style strippers. They are designed for woodwork, to be used indoors, and to remove the stuff in layers (you apply the remover, let it stay a while, then grab one of the wrinkled ends or edges and pull slightly and away it all comes in a hunk if everything works according to plan. And yes, I actually had it work as claimed on the package). The stuff "Ain't" cheap, but the time and effort of trying to get all of the gunk out of all the cracks and crevases makes the stripper a bargain in the long run. Another option would be to take all of the stuff to a professional furniture stripper. Then it's their problem getting rid of the contaminated paint and gunk , no free ride because you're paying for the service...
