Air compressor having a hard time starting
Christopher
11-23-2001 18:18:51
I have a Campbell Hausfield compressor, 10.3 cfm that has been really laboring when it starts, it seems to be running at about half rpm for quite a while, I thought it might be the cold weather but it has been in the low 40's and last winter I used it at -20 below zero and it didn't seem this bad. I have the CH commercial oil in it and it does seem thick when cold. Can I put diferent oil in it? What would you guys suggest? Thanks, Chris
JHILL
11-26-2001 09:45:20
 Re: Air compressor having a hard time starting in reply to Christopher, 11-23-2001 18:18:51
If it is a 220 compressor make sure you are getting power on both of the 110 circuits.
Christopher
11-26-2001 07:29:53
Thanks guys for your help, I think I have narrowed it down to the oil being too thick. it is only one year old and last winter I had the original oil in it, it must have been thinner. yesterday I put an oil heater on it to see if it would make any diference, it did make a noticeable diference, not like summer but better than it was. I am going to move it into another building that I can have a small, heated room for it, as well as look into synthetic oil, I had to go with synthetic transmission fluid in my pickup since I couldn't shift it in the really cold weather very well, now it works like summer almost. Does anyone have any suggestions on oil to use? I want a good oil because the compressor is still under warranty. Thanks again, Chris
John, IN
11-27-2001 15:10:55
 Re: Re: Air compressor having a hard time starting in reply to Christopher, 11-26-2001 07:29:53
Mobil 1 synthetic motor oil is the way to go. A CH service man told me that.
Roger
11-25-2001 19:43:00
Are you running it through an extension cord?
Greaseman
11-24-2001 14:05:25
I agree with the other's regarding the "unloader", But would like to add just one more thing; you may want to check to make certain that your valves are adjusted properly!!
Jon Hagen
11-23-2001 20:30:53
Might have a weak start capacitor in the motor, or a loose belt and as the others said the unloader not working. I used to have problems with my compressor blowing the breaker when temp was -20 or colder in my unheated shop. I cured the problem about 15 years ago by using Mobil 1 synthetic motor oil,5W30 and now 0W30. Starts right up at -35 and no bad effects from using motor oil all those years. I did not know that there is a synthetic compressor oil.
fzbcheve
11-23-2001 18:33:23
check to see if the unloaded valve is working. Have been using 10-30 im my CH for years. Seems to work very good.
Ray,IN
11-23-2001 20:06:39
 Re: Re: Air compressor having a hard time starting in reply to fzbcheve, 11-23-2001 18:33:23
I agree, the unloader valve sounds suspect. I installed synthetic compressor oil to solve cold weather problems and my compressor runs much easier all year.
JMJ
11-25-2001 08:51:55
 Re: Re: Re: Air compressor having a hard time starting in reply to Ray,IN, 11-23-2001 20:06:39
I have one just like it when mine did that it was the moter it has a start switch in it when it get up to a speed it speeds up it works like a govener the switch gets dirty it need to be cleaned and lubed
