Knipco heater
Bruce
11-21-2001 04:22:46
Hi just wondering if any one could help if they know the web site for knipco heater i need a manual for one i need to repair i bought at a auction this summer thanks
Gene Davis
11-22-2001 06:40:59
 Re: knipco heater in reply to Bruce, 11-21-2001 04:22:46
When repairing my kerosene burning one, the manual said the atomization pressure was 2-1/2 -3 lb, checked with a very low pressure gauge, preferably not more than 10p.s.i. If the atomizing nozzle is dirty it will not spray a clean,good pattern to burn properly and will smoke and smut up the whole area. Gene Davis
tim
11-22-2001 05:54:08
Reddy heater remington john deere and many outhers made by desa international ingitors on all (sparkplug) need low presser gage 5/7 lbs to test nozzle to high to much fuel fumey to low cuts in out we service them at work
tim
11-27-2001 03:53:55
 Re: Re: knipco heater in reply to tim, 11-22-2001 05:54:08
I will check books at work and get back to you
bruce
11-27-2001 04:09:42
 Re: Re: Re: knipco heater in reply to tim, 11-27-2001 03:53:55
thanks tim
tim
11-30-2001 02:16:50
 Re: Re: Re: Re: knipco heater in reply to bruce, 11-27-2001 04:09:42
I havent forgoten except when at work sorry today I will remember !!!!!
bruce
11-22-2001 06:29:12
thanks tim
do you know what the nozzle pressure is on a f-98 model and co 2 and smoke if you know that to i can get a tester to adjust it to the right setting if i know what they are or maybe a little better for less fuel waste any other information would be gratfull thanks bruce
steve
02-16-2003 08:12:59
 Re: Re: Re: knipco heater in reply to bruce, 11-22-2001 06:29:12
i have an older knipco 63,000 btu, which will run for a few minuts then kicks the reset out and quits. this cycle gets shorter the more i try running it. any suggestions?
rob trussell
11-16-2006 19:56:26
 Re: Re: Re: Re: knipco heater in reply to steve, 02-16-2003 08:12:59
i have the same problem. did you ever find the answer or a manual?
rob
jeff
11-21-2001 06:59:38
Knipco is made by Koehring Master division in Dayton Ohio 45401
