XMT-304 CC/CV
Mark Kw
11-19-2001 11:58:29
I am seriously considering purchasing one of these and would like some real world feedback on them. Primary use will be stick and mig but likely will do some tig as well.
Thanks,
Mark Kw
JRN
11-19-2001 21:20:49
 Re: XMT-304 CC/CV in reply to Mark Kw, 11-19-2001 11:58:29
I can�t get the numbers to work when you buy all the goodies to make the XMT-304 do it all. A new Miller Dynasty TIG Runner will set you back 5 grand and a new Miller Millermatic 251 is around 2 grand. After you buy the XMT-304 and all the accessories to do Stick, MIG and TIG at the same level of the other machines would be 7 grand or more. I�ve pondered the same and would like to hear what others think but I will throw in the towel on who will die with the most toys. . . Mark or I.
David Bean
11-19-2001 15:25:07
Mark,
I've got my eye on an XMT-304 as well. When I took welding classes last year, I played around with an XMT on aluminum, and it worked fine. The school where I took the classes used XMTs for all their stick work areas, plus MIG on stainless and aluminum. There are three things I like about it:
1. It's multiprocess so I can later invest in some TIG equipment.
2. It's inverter based so it's light enough to easily move from one shop to another.
3. I want to experiment with pulsed MIG and the XMT will let you do that (with the added controls).
I suspect your budget will let you get one before me, so have fun on my account, will ya?
- David
wh
11-19-2001 12:22:02
have one for students to train on. very reliable and excellent arc control. have set up with flux core wire. really like it. wade
Mark Kw
11-20-2001 04:34:01
 Re: Re: XMT-304 CC/CV in reply to wh, 11-19-2001 12:22:02
Many thanks for the input. I'm looking to use it not only in my shop but also to take with me into plants and other areas where I have power available and or can't use the engine drives.
Most of what I do is bigger stuff, pipe, structural and heavy equipment. The occasional tig job does not come around as much as I'd like it to. I talked to Miller and got the details on the machine which cleared up some concerns I had about it. The 14 pin connector allows for use of the S-30A spool gun w/ WC-24 control box (already have) It also accepts the RFCS-14 foot controller for tig. My S-64 will also plug into the 14 pin connector and the S-32S is voltage sensing so it'll run as well.
I like having the ability to 'plug in' and use all my existing equipment with this power supply. I was somewhat concerned about the supply itself. In addition to the above, I like the auto-link deal where I can plug into any power from single phase 240 to three phase 480 without having to constantly waste time changing hard wire configurations.
Thanks again for the input, much appreciated!
