What type of tacometer
don s
11-15-2001 22:09:47
need help what type of tac. would work on a wisconsin v4 with a magneto ignition?
This has a wird timing arangement
firing order #1>180 deg.#3 270 deg #4 180 deg #2 90 deg # 1 they rotate the rotor in a anti clockwise direction and the mag fires at each lead ( I hope this makes sence ) thanks
Bill
11-16-2001 06:09:52
 Re: what type of tacometer in reply to don s, 11-15-2001 22:09:47
Sears also carrys the tach/hour meter. I saw some there a couple of days ago. Can't remember the rpice thought. It was in with the lawn and garden replacement parts.
Bob M
11-16-2001 04:54:25
Don - Probably the cheapest solution is to put a "Tiny Tach" on your engine. This is a self-powered digital tach/hour meter. It senses RPM inductively from a wire you wrap a few turns around one spark plug lead - it'll work great on a magneto-equipped engines like your Wisconsin.
Best price Tiny Tach I've found is from Northern Tool (www.northerntool.com) - about $35. Be sure to get the one for 4-stroke engines that fire once every other crank revolution.
