Actron multimeter
measuring rpm
Jerry (NH)
11-15-2001 09:30:56
I want to measure RPM on a Ford 8N tractor (4 cylinder) to see if the proofmeter is way off.
I've gotten hold of a Actron multimeter that has an RPM setting and a clip-over inductive lead. Do I simply clip this over a plug wire? Or the coil wire? Will it display RPMs directly or do I need to multiply/divide/whatever? Any other hints?
Thanks,
Jerry
Big Jake
11-16-2001 08:49:50
 Re: actron multimeter - measuring rpm in reply to Jerry (NH), 11-15-2001 09:30:56
I believe the meter uses the coil for it's Tach
reading. Do you know what model you have?
Actron has the user manuals available on line-here is link to one model
http://www.actron.com/cgi-bin/web_store.cgi?page=cp7678.htm&cart_id=4552917_7212
Jerry (NH)
11-16-2001 10:33:25
 Re: Re: actron multimeter - measuring rpm in reply to Big Jake, 11-16-2001 08:49:50
It looks like Actron model CP7680.
Did a quick try last night, but I hooked it up and the reading was weird. It wouldn't give a reading in the normal range of 0-3000. I had to set the switch to RPMx10 and then it would read something like 1800 - not something outside that 0-3000 range. I think I had the clip going in the right direction and far enough away from other wires.
So I remain confused,
Jerry
Tyler(WA)
11-15-2001 10:30:56
Inductive pick up RPM meters are accurate enough and they generally clip to the #1 plug wire (though it really doesn't matter which plug wire you use.)
Number of cylinders shouldn't matter because a 4 cycle engine will turn two revolutions per spark regardless of how many cylinders.
It's real tough to use on diesels, though.
Jon Hagen
11-15-2001 19:57:55
 Re: Re: actron multimeter - measuring rpm in reply to Tyler(WA), 11-15-2001 10:30:56
All that Tyler says except read rpm on the 4 cyl scale. If the meter has only 6 or 8 cyl scale,then use the 8 cyl scale reading X2 for a 4 cyl.
Jon Hagen
11-15-2001 20:03:08
 Re: Re: Re: actron multimeter - measuring rpm in reply to Jon Hagen, 11-15-2001 19:57:55
WHO!! Major brain fade on my part, I was thinking electronic tac/dwell meter. With the inductive pickup meter Tyler is right,number of cylinders makes no difference, Sorry.
Tyler(WA) Did the same thing...
11-16-2001 09:01:09
 Re: Re: Re: Re: actron multimeter - measuring rpm in reply to Jon Hagen, 11-15-2001 20:03:08
Don't feel bad, Jon.
I had my whole response written with a few paragraphs devoted to 1,2,4,6 and 8 cylinder "differences" when I finally came out of the ozone and realized 'hey, wait a minute...'
Glad you relieved me of thinking I was alone.
