Spring Tooth Harrow???
MO
11-14-2001 13:51:27
I have the chance to pick up a spring tooth harrow to pull behind my 9n. It looks to be about seven feet wide. First of all, is this size allright for my 9n? Secondly, is it something that I should even be interested in, or will disking the soil be plenty? Thanks for the advice,
MO
Keith
11-16-2001 08:10:26
 Re: Spring Tooth Harrow??? in reply to MO, 11-14-2001 13:51:27
If you can agree on a price buy it. After I plow I harrow before drilling winter wheat. I only have a flat harrow sections. My neighbor has an old set of spring tooth harrows and they do MUCH prettier work. I wish I could find some. I would need at least 4 sections.
F14
11-14-2001 14:33:38
Size should be fine. As to whether you "need" it or not...
Depends on your ground. If your disk leaves a lot of clods, the spring-tooth will tend to bust 'em up and level things out.
