Cleaning carb plarts
bruce
11-14-2001 04:25:06
does any one know of a solution to soak carb part in like the copper float is all crude on the out side i thought maybe i could soak it in some thing a while to clean it off thanks
trucker
11-15-2001 20:45:06
 Re: cleaning carb plarts in reply to bruce, 11-14-2001 04:25:06
If you have an Auto Zone parts place close to where you live,they most likely have a gallon can of carburetor cleaner for about 10 dollars.It comes with a basket that you can put all the small parts in and soak them overnight.They will be clean when you pull them out,and you can reuse the cleaner.
Michael Lewis
11-15-2001 19:58:46
I just got done with an 66 Ford 3000 engine rebuild. At first I laughed when my brother suggested this cleaning method, but it works and it works well.
Take a small bucket or coffee can (depending on the size of the parts) and fill it about 3/4 full with boiling (it must be boiling) water. To the water add about 1/2 cup of Simple Green (a little more if you have a large bucket.)
Add your parts (as unassembled as possible) to the mixture and let them soak.
I know this sounds rediculously simple, but it works like a champ. I was able to use a nylon brush after about 20 minutes and get my carb and pistons almost shining like new. On the pistons, nearly all of the baked on carbon was gone and I was able to softly brush off the varnish from the float and bowl.
Keep in mind that this will expose all steel parts to water and air. You must make sure to lightly oil all the parts after removal from the water. If the water is hot enough, most of the moisture will evaporate quickly, so you will want to oil them fast. Make sure to use a CLEAN and lint free cloth. I also found that putting the parts into plastic bags (gallon size or roasting bags) after this cleaning helped to keep dirt off and it minimized the exposure to the air.
Hope this helps. I found it much better than messing with all the harsh chemicals.
ShepFL
11-15-2001 05:57:56
Bruce -
I use B12 Chemtool to clean my carbs. Have never seen it in bulk quantities though, may have it just never seen it. Works real well cleaning varnish etc.
Another thing we used to clean aircraft parts with was MEK (Methyl-Ethyl Ketone). It was bought in 55 gal. drum. This stuff will clean just about anything but it is toxic. Use gloves and safety glasses. Can absorb into your skin quickly, REALLY dries out your hands and made mine crack. Check with autobody shop or municipal airport for local sourcing.
HTH
Mac
11-14-2001 09:34:05
Bruce: Check with an auto parts store, I used to get it by the gallon. I think in the submersible type a gallon is about the least you can get, however you can use it more than once. I just put what I had left back in the container.
Redtractorman
11-14-2001 07:03:13
They make regular carbuator cleaner that you soak all metal parts in .
