Stuck PTO Shaft
PeterFromNY
11-13-2001 10:49:51
Advice Appreciated. I have a sickle bar where the PTO shaft doesn't telescope anymore. It's the square stock. I had the implement mounted with the shaft loose and a come-a-long on the end of the PTO running under the tractor and hooked to the front of the tractor. I put considerable tension on the PTO and rapped on it for 15 min. with a hammer. I would heat but it has the PTO shaft cover in place. Any ideas? Thanks
Jerry
11-14-2001 07:51:43
 Re: Stuck PTO Shaft in reply to PeterFromNY, 11-13-2001 10:49:51
I had that happen to me and I chained one end to a tree and the other to my tractor and it came right out. I had pounded on it and used the come along to no avail for about a half hour
David C. Baker
11-14-2001 20:03:10
 Re: Re: Stuck PTO Shaft in reply to Jerry, 11-14-2001 07:51:43
Atta boy!!
Matt
11-13-2001 15:43:56
If the safety gaurd is metal, you might be able to heat it enough to soften the grease a little. If you kept tension on it, I don't think it would take much heat. Could be wrong. Good luck.
Matt
bbott
11-13-2001 12:36:32
You might try using a slide hammer chained up to the yoke first, if that won't work I'd take the cover off and give it a little heat.
I had one stuck like that last year on a fertilizer spreader..
I tried everything, finally used a slide hammer, but it still didn't budge until I heated it up a little and melted some of the old hardened grease inside.
-- bb
bbott
11-13-2001 12:36:29
-- bb
Thanks Everyone. WIll try
11-14-2001 05:37:10
 Re: Re: Stuck PTO Shaft in reply to bbott, 11-13-2001 12:36:29
qqq
