Oil additive
Roy
01-04-1999 17:58:38
I have a gentlemen that is trying to sell me A OIL addive it is called Bi-Tron. I suppose it is similar to a product like slick 50. It is supposed to help with the metal to metal contact. Can anying one advice on this.
Dieseldog ONT,CAN
02-12-2001 13:25:36
 Re: oil additive in reply to Roy, 01-04-1999 17:58:38
Roy If your looking for a legitimate oil additive with Teflon check out Tufoil at www.tufoil.com. Its a patented and government tested product that I have personally used to cure premature wear and noise problems in transmissons,differentials,motors and transfer cases and I swear by it. Good Luck Dieseldog!
Dieseldog ONT,CAN
02-12-2001 13:25:25
MikeH(Tx)
01-05-1999 17:42:04
Roy, I have read numerous articles on Slick50 and similar products. At first, all the article were negative, very negative. Then, after a couple of years, they have progressed to the point where only half of the articles are negative.
My personal opinion: Someone gave me a quart of slick50 about 5 years ago. It's still here, want it? Same goes for the rest of the additives. The only innovation that I am a believer in regarding oil is synthetics. And even then, there is a bundle of opinions that say I am wasting money.
Plant Doctor
01-07-1999 05:05:24
 Re: Re: oil additive in reply to MikeH(Tx), 01-05-1999 17:42:04
I agree with Mike, I was talking to a chemist from the Mobile Oil Co. and I think he said it best. The major oil companies spend millions on research and if these miracle additives were as great as the salesmen make them out to be, the oil companies would have that product or a similar product already in the oil they sell.
Dusty
01-11-1999 20:15:02
 Re: Re: Re: oil additive in reply to Plant Doctor, 01-07-1999 05:05:24
Go to OldEngine.org under FQA page there is an article, Is That Additive Really A Negative? I belive it is well worth reading.
Good luck, Dusty MI
Rob Poet
01-19-1999 19:53:44
 Re: Re: Re: Re: oil additive in reply to Dusty, 01-11-1999 20:15:02
It has been my experience,especially with old tractors, that any oil sold today is still better than the stuff they used in them when they were new. My opinion is buy the best oil you can find and use the best filters, and you can't go wrong.(ps, I've had two oil distributors tell me that Castrol GTX is the best on the market for gas engines. These dealers did not sell castrol. Quite a testimonial, eh?
Pete
01-22-1999 02:54:02
 Re: Re: Re: Re: Re: oil additive in reply to Rob Poet, 01-19-1999 19:53:44
Tried Slick 50 in a 77 ford 460, rear main started leaking almost immediately, finances kept me from fixing it and after about a year and several oil changes without Slick 50 the leak finaly stopped by it's self. Havent used it si
Pete
01-22-1999 02:45:29
George
01-04-1999 22:01:17
The salesman will make more money on it than you will.
Russ NY
01-14-1999 16:17:39
 Re: Re: oil additive in reply to George, 01-04-1999 22:01:17
In ref. to a comment on synthetic oils. I took an old B&S motor (sat for 20+ yrs checked the oil it was dirty but oil anyway. Put in gas and it fired right up. Drained it put in regular 20/w and it was fine. Drained it and added 20W MOBIL #1 and it immediately poured out pass the crankshaft seal. Went back to regular 20W and no more problem "ever". You be the judge . I dont think old iron and old seals are compatable with synthetic oils.
CHARLES ROBSON
04-14-2000 22:02:51
 Re: Re: Re: oil additive in reply to Russ NY, 01-14-1999 16:17:39
I tested Bi-Tron and many other product on a cross-axis machine over a two month period. There is nothing to compare to Bi-Tron. their are a lot of good products out there, but I find Bi-Tron to be the best. Everyone that I know using it has gotten more than 20% increase in fuel economy and all the other benefits stated in the literature.
We have had an incident, where a head gasket let go - antifreeze into the crankcase - and did not damage the engine! check out a site I visited just before yours ->Link
Yes>Link I am a novice to the web. - three weeks young!
