Hey T Bone
Mike
11-08-2001 07:41:34
refresh my memory please! I do most of my stick welding w/ 6011 to cut and burn and 6013 to cover the 6011 and pretty it up. I just got an unpened 50# tin of 8013 at an auction (13$) What are the properties of this rod???? Thanks, Mike
Mark Kw
11-08-2001 11:42:06
 Re: Hey T Bone in reply to Mike, 11-08-2001 07:41:34
I've never come across an 8013 or even heard of these being produced. With the exception that I missed something along the way, most likely these are in reality "8018" or "6013" with one of the numbers not printed correctly. (just a possibility) If they are actually an 8013, that means 80,000# tensile strength, all position, coating is high titania & potassium. If they are an "8018" they are also all position with the coating being iron powder, low hydrogen, potassium.
In the designation of stick electrodes, the first two digits of a four digit number or the first three digits of a five digit number code are the tensile strength in thousands of PSI of the weld bead. The third digit indicates welding position the rod may be used in: xx1x: all position
xx2x: flat or horizontal
xx4x: flat, horizontal, overhead, vertical down.
The fourth digit indicates power supply and or covering composition.
Occasionally a suffix letter, number or combination may be used on electrodes such as "E12018-B2" These vary from mfg to mfg so you should contact the mfg for specific data on these type electrodes.
Hope this helps. Mark Kw
Mike
11-08-2001 12:43:01
 Re: Re: Hey T Bone in reply to Mark Kw, 11-08-2001 11:42:06
glad somebody was paying attention during welding school! I haven't opened the box yet but had already considered it maybe 6013 as the #s are written on the box w/ crayon. Thanks, Mike
