Husky ignition woes
Neil O
11-04-2001 17:07:50
Help! Offered to fix a seniors Husky 272XP saw for him - he said the coil was dead and had tried another from a neighbors saw and it worked. Lucked out and got an old one from a repair shop cheap because the engine had cratered but when I put it in - no spark. Finally ordered a new one - put it in -no go. Whats up? These are the external to the flywheel coil w/2 leads - one for the plug and one for the switch. Super simple. Gap good, magnets seem OK. What am I missing?
Jake
11-06-2001 21:46:09
 Re: Husky ignition woes in reply to Neil O, 11-04-2001 17:07:50
Check on this chainsaw forom,if this link works.Walt or Yukonjohn should know.Jake
Scott ks
11-06-2001 20:19:50
To be quite honest I am at a loss. When you get this thing fixed let us know please. In your original post you said that you borrowed one and it ran. Have you tried your parts on the other saw to see if it would run with the parts you purchased?
I would be game for that.
Scott
T_Bone
11-06-2001 03:44:08
Hi Neil,
I would look at a bad ground on the sparkplug?
If the coil had two simular leads then try the other lead to sparkplug?
Bad switch?
Bad sparkplug?
It's got to be something simple as you had it running with another coil.
T_Bone
Scott Ks
11-04-2001 17:42:55
Hi Hand an old echo that did that sometimes. Wire from switch got a bare spot in it and would ground out and start after a while. Check the flywheel key also.
Scott ks
Neil O
11-05-2001 16:00:17
 Re: Re: Husky ignition woes in reply to Scott Ks, 11-04-2001 17:42:55
Thanks for the reply, Scott. Actually don't even have the switch wire connected so thats out. Even when the magnets pass over the armature, it generates no juice so if the flywheel key was sheared, there should still be a jolt. Not familiar with this ignition system and how it creates a field and breaks it abrubtly without the use of points or CDI. Anybody know if it has to do with the 2 magnets in the flywheel?
Scott Ks
11-05-2001 18:14:28
 Re: Re: Re: Husky ignition woes in reply to Neil O, 11-05-2001 16:00:17
One other thought is this an old saw? The bearings seem ok in the crankshaft and not letting the gap get out of wack? Scott
Neil O
11-06-2001 04:40:32
 Re: Re: Re: Re: Husky ignition woes in reply to Scott Ks, 11-05-2001 18:14:28
The saw is a 1994 and still in good shape. The bearings don't seem to show any slop or play at the flywheel end.
Wayne Gloff
11-07-2001 19:07:01
 Re: Re: Re: Re: Re: Husky ignition woes in reply to Neil O, 11-06-2001 04:40:32
Is there only one coil or is there a coil with a module somewhere else. Husky did use a coil and separate module on many of its saws.
