DeWalt DW872 (UPDATE)
Marvin(MN)
10-29-2001 22:49:50
Some of you asked for an update on the saw. Well I got to use it this weekend and I was very impressed with it. It's like using a miter saw only it's on metal. No sparks and very little burrs and no heat. With that said I love it.
Hopes this helps.
Marvin
DumOleBob
11-08-2001 17:14:28
 Re: DeWalt DW872 (UPDATE) in reply to Marvin(MN), 10-29-2001 22:49:50
Hey Marvin - like I said - a long time ago. You are going to love it. However, keep in mind the some what expensive blades can be resharpened a number of times! Relax & cut away!!
bbott
10-31-2001 13:15:22
Marvin,
Thanks for the follow up... now I'll have to start leaving hints around for the xmas list.
Heavy Metal
10-30-2001 20:32:20
Great news that you liked it, but could you tell us what you cut with it? Some of us (mainly me) questioned its ability to cut heavier steel that I usually work with. What do you feel its capabilities/limitations would be? again, I cut iron up to 1", drill stem (surplus oil field) pipe which is up to 1/4" thick walled depending on how rusted it is, and 3/4 sucker rod, flats, angles, making pipe fencing, corrals, gates, loading chutes etc etc etc. How long would this carbide blade stand up to that? 125 seems pretty darn high for a replacement blade....my DeWalt abrasive chop saw cost 199 new and has lasted for two years now and going strong. The one before that was Makita and lasted 4 years till the housing and frame was worn out (motor still ran).
Marvin(MN)
10-30-2001 21:24:33
 Re: Re: DeWalt DW872 (UPDATE) in reply to Heavy Metal, 10-30-2001 20:32:20
H M. I cut some sq.tubing and some 3/4 cold rolled round. The sq. tubing was only 1/8" wall but was 1x2 & 1x1 no problem. Like I said no heat and no burrs.
Marvin
