Mig Welding Question
Chopper
10-23-2001 11:51:21
I am a novice welder. Using a Millermatic 175, solid wire w/gas.
I am trying to weld 5/16" rod end to end, however keep melting the wire into the tip.
What settings should I use?
What am I doing wrong?
Thanx in advance.
Chopper
F14
10-23-2001 14:48:58
 Re: Mig Welding Question in reply to Chopper, 10-23-2001 11:51:21
I'm just a self-taught junkyard welder myself, so others may have better advice, but it sounds to me like you need to turn your wire feed speed up a tad.
Once you have the heat range set for proper penetration, set the wire feed speed to maintain about 1" or so of "stick out" while maintaining a good stead arc.
F14
10-23-2001 14:46:13
Turn your wire feed speed up a tad. When you get the heat range set for the right penetration, crank up the wire speed to keep the proper amount of "stick out" so the tip stays about an inch away from the work, while maintaining a good steady arc.
I'm just self-taught junkyard welder myself, so others may have better advice.
