Metal Identity?
Nathan(GA)
10-17-2001 16:32:29
How does one tell the difference between cast steel, malleable steel etc.? One guy says it's cast steel, another says malleable steel. I cut it with a torch. It center punches fairly easy, but the way it broke was like cast iron. It has a grainy texture where it broke.
It's the part on a back hoe that connects the hoe with the hydraulic swing motor. It's two plates 3/4" thick each with a gusset inside. It has factory torch marks when it was made. It's a '71 model.
I need to know what rod to weld with and if mild steel can be welded to it.
Thanks
Nathan(GA) - Thanks! n/t
10-19-2001 19:35:50
 Re: Metal Identity? in reply to Nathan(GA), 10-17-2001 16:32:29
n/t
jim
10-18-2001 21:20:31
most likely cast steel. weld with 7018 or better.
Rod MI
10-17-2001 23:01:17
The best way is take it down to a heat treat place and have them spark check it for you but if you get sum negligible welder they mite be able to help you out with sum thing that should work (where is TBone when you knead him) good luck rod
