Int'l 560 distributor counterweight springs
JCW
10-17-2001 06:42:51
My tractor idled fine but wouldn't keep running at higher RPMs. I has a valve job done and machined the head then discovered my distributor had too much play in it. With my neighbors help, I took it apart and found the bronze bushings were worn. One was even broke in two. Oddly enough the exploded view of the distributor at the parts store doesn't show the lower bushing. It shows a bushing above the gear but not one below. I can't imaged they'd have steel running on steel there though. But it does appear the shaft below the gear has been turned down and the ID of the lower bronze bushing was not a standard size. I had to buy a heavy wall bushing and bore out the ID. So some modifications must have been made in the past. (This is just for curiosity, what is down there if there's no bronze bushing between the housing and the shaft? That would mean the OD of the original shaft at some point was greater than the OD of the gear. Seems odd.)
ANYWAY, here's the real question. When we took it apart we observed that the expansion springs on the counterweight were different. Different wire diameter, coil size, coil length and number of coils. It didn't make sense to have two different springs on the counterweights. We assumed someone had changed one in the past and that's what caused the excessive wear on the bushings. So I ordered new springs, only to receive, packaged together, two different springs just like the ones I removed. Now I don't know which spring goes where???? and why in the world would you have different amounts of spring pressure on the counterweights?
RONALD W PROVO
10-24-2001 17:15:28
 Re: Int'l 560 distributor counterweight springs in reply to JCW, 10-17-2001 06:42:51
I recently repaired my International distributor and changed it from points to solid state. I replaced the top bushing, which is 7/8 o.d. dia. and reamed it out to 1/2 I.D. bore and replaced the bottom bushing, which is 1/2 I.D. bore and is paper thin. So you probably have a better bushing than what the factory installed. I did not notice any difference in the spring size. International made their distributors to be converted to counter-clockwise or clockwise. But still it doesn't make sense to me (as you) to have different springs.
IHank
10-17-2001 08:46:07
The springs you have are right. That is the way IH made them.
Hank
