To solder or J B Weld
Jim in N M
10-16-2001 17:03:33
I need the experts!! a little off tractors but--- I have a pair of Harley tanks to install a 3/16 steel line going through a 1/4 steel equalizer line to keep the gas equal level.they have a custom paint job.can I use J B Weld instead of trying to solder and will J B leak gas please help me out on this one JIM
Heavy Metal
10-24-2001 19:39:54
 Re: To solder or J B Weld in reply to Jim in N M , 10-16-2001 17:03:33
For Petes sake.....have the thing brazed not soldered. JB weld should be called NR weld ( for N_____ rig). is mixed incorrectly this stuff is garbage. Do the right thing and make it last forever.
Paul
10-20-2001 19:58:25
I once talked to a crippled up guy who had stepped off of a blazing Harley at about 50 MPH. He said he was able to make about three fifty foot steps before his world fell apart. The mailbox that he hit didn't do him any good either. I think I'd braze and repaint. I used to run one side out and switch to the other. Helped me remember to refuel. Good luck!
John Mann
10-17-2001 15:07:56
I suggest brazing 2 barbed hose fittings in each half and using a rubber oil resistant hose to couple them. this way you can separate the pair and do the brazing prior to paint.
Fred OH
10-17-2001 06:02:48
My opinion is too much vibration for J B Weld or soft solder. I would recommend silver solder or brass (brazing). Which do you want- pretty paint or dripping gas. This is a critical thing....Why didn't you think of that???
I saw a Harley burn completely up at a Burger King in Lebanon, Ohio because of a little gas leak. L8R----Fred OH
Franz
10-16-2001 22:42:02
A much better product than JB Weld is All Weld.
It's made by Forney Industrys, and comes in a plastic tube with a silver paper insert. Seems to be turning up at most suppliers. This stuff really works, and STOPS oil leaks.
You cut off what you need, knead it together and apply. I've had some patching 2 oil pan leaks for over a year, and it's still holding. We've also used it on seam leaks on gas tanks, and it holds.
The machinability after curing is a lot like Devcon.
If you're not going to read the instructions, I'll tell you, wet your hands before kneading it, or you'll wear it for a while.
Best of all, it sells for around 4 bucks for a 2 ounce package.
tools
10-16-2001 22:28:25
Hey Jim,
Have used JB weld on gas tanks in an emergency but never permanently. I don't think it will work well for you. Soldering won't either. You might be thinking of brazing, which will work fine, as will proper welding. Of course the tanks will have to be FREE of gas and fumes!
Wait and better educated responses will come along, this is a fine site. Good luck.
Tools
Terry
10-17-2001 16:06:36
 Re: Re: To solder or J B Weld in reply to tools, 10-16-2001 22:28:25
Its no Harley but i used JB WELD on a gas tank in a 50 Chevy pickup about 25 years ago and its still holding to this day. I have also used it on an oil pan and an engine block without any problems what so ever. I`m sure there are more advanced products on the market today for your type of application but the JB Weld has done me good so far. Take care,Terry
