Gas power hedge trimmers
Craig
10-15-2001 07:39:20
I have a Echo gas power hedge trimmer that is giving me fits.It runs fine for about the first ten minutes, then it starts to bog down and shut off. I replaced the plug and still the same problem. I also made sure that the fuel was fresh and I use the same mixture in my weedeater with no problems. It almost seems like it is not getting any fuel after it is hot. Any ideas?
Thanks
Nathan(GA)
10-15-2001 19:53:34
 Re: Gas power hedge trimmers in reply to Craig, 10-15-2001 07:39:20
Check the fuel filter, air filter and muffler. Any or all may be clogged.
roy
10-16-2001 15:39:46
 Re: Re: Gas power hedge trimmers in reply to Nathan(GA), 10-15-2001 19:53:34
You have a clogged muffler.
i had the same thing happen to my weed eater.
Craig
10-17-2001 03:08:15
 Re: Re: Re: Gas power hedge trimmers in reply to roy, 10-16-2001 15:39:46
Thanks for the help! I will check to see if the muffler is clogged.
