Model A clutch
Fred Baker
10-14-2001 20:05:43
I have a JD Model A (578719) and I need to know how to properly align the clutch disc on the out-put shaft. The service manual says to line up the "V"s to make an "X" but there are none to be found on my unit. I know that it is criticle to install properly as it is counterweighted. Also what is the minimum thickness for the clutch friction plates? Any help would be apriciated.
FSB
Jerry S
10-24-2001 12:39:57
 Re: Model A clutch in reply to Fred Baker, 10-14-2001 20:05:43
I just now saw the post and would recommend you post this in the John Deere board. There are lots of helpful guys there who know this answer. I was wondering if it is possible that the V was on the other side of the disc? You are right that the clutch disk is counter balanced of the flywheel so alignment is important.
