Diesel glow plugs
Jerry
01-01-1999 21:11:55
I need to find out how to take glow pluges out and which kind of tool it takes. Thanks.
JEFF WALDSCHMIDT
01-05-1999 12:31:20
 Re: Diesel glow plugs in reply to Jerry, 01-01-1999 21:11:55
SNAP ON MAKES A SOCKET FOR TAKING GLOW PLUGS OUT. BEST BET IS TO GET A CATALOG FROM THEM. YOU CAN CHECK PLUGS WITH OUT REMOVING FROM ENGINE BY PLACING ONE END OF 12 OR 24 VOLT TEST LIGHT ON BATTERY & OTHER END ON GLOW PLUG WHERE WIRE HARNESS ATTACHES. IF THE LIGHT LIGHTS UP YOUR GOOD TO GO
richard
01-16-1999 11:13:03
 Re: Re: Diesel glow plugs in reply to JEFF WALDSCHMIDT, 01-05-1999 12:31:20
TO TEST GLOW PLUGS WITH OUT REMOVING FROM THE ENGINE IT MAY BE GOOD IDEA TO USE A MULTI METER AND CHECK AMPS.A BALL PARK FIGURE IS 6 AMPS PER PLUG.
Norm
01-02-1999 02:35:26
I use a deep well socket or a boxend wrench if possible.
welder
01-03-1999 19:08:33
 Re: Re: Diesel glow plugs in reply to Norm, 01-02-1999 02:35:26
otc tool co. makes a tool to get out stuck glow plugs with out braking them
