Sand blaster
mgb
10-12-2001 20:14:48
Hey, has anyone got one of the little sand blasters that Harbor Freight is offering? Are they any good? I sure could use one.
John ('48 Cub, Ohio)
10-15-2001 03:49:39
 Re: sand blaster in reply to mgb, 10-12-2001 20:14:48
Which kind are you asking about? Notice that your replys are describing two types that HF sells. The blast cabinets or the little pressure blasters. Both types have their place but are generally used for different jobs.
Zira
10-13-2001 18:03:27
My experience has not been positive. I got one as a Christmas gift last year. The hose had hardened & cracked, HF replaced it but it took 3 1/2 months. It was an odd (metric?) size, I had a very difficult time finding a replacement locally. The sand hopper in mine is too shallow, the pick up tube runs dry all the time. The light kit is a joke, I made a shade to keep it from shining into my eyes all the time. The door leaks sand. And while a shop vac works okay as a dust collector, it is noisy and not really meant to be run continuously. Make sure you keep the paper filter installed, the foam filter alone doesn't cut it alone.
All that said, I have used it a lot. They are a very handy thing to have.
DumOLeBob
10-14-2001 10:10:45
 Re: Re: sand blaster in reply to Zira, 10-13-2001 18:03:27
Zira's comments are EXACTLY what I found. Then I got a TIP unit & it is the exact opposite of what he describes. TIP makes really fine blast cabinets.
DumOleBob
10-13-2001 06:26:18
The one you ask about MAY be ok, but do yourself a favor & check out Eastwood & TIP Tools. Either has REALLY good blast cabinets - not just - may be OK - in the short haul. Eastwood just came out with a new top load, bench model which may be a sale. TIP cabinets are AAA+++. It's China vs the USA all over again! The whole thing is the quality of the gun, pickup tube, etc.
www.tiptools.com & www.eastwoodco.comn
gene b
10-13-2001 03:56:13
yes i got the 40lb model a while ago when on sale for 55 i use the 1/8 tip set my reg to 70lbs use for smaller stuff works just fine get my sand from supplier for 26 a ton also have a bigger one i made from a 100lb lp tank have a port compressure 75cfm at 80lbs the smaller blaster runs off my electric compressor it is rated 11cfm at 90lbs ANY sandblaster needs a compressor that will handle what the tip opening calls for glad to help
LarryG
10-17-2001 04:49:35
 Re: Re: sand blaster in reply to gene b, 10-13-2001 03:56:13
I'm getting a little disappointed with my 40# pressure sandblaster from HF. The first part of my problem was my fault because I didn't strain the fine sand I bought from Home Depot, and I had to stop every few seconds to disassemble the nozzle to clear it. I wore out the nozzle valve from shutting it off to take it apart. Now "shut off" is a relative term. Now it seems to pulse - it will run lean, then flood out with sand and when it does that, the sand sort of drools out without much velocity. I'm wondering if this is what I am to expect from this unit. I didn't really want to spend $500 +/- on a sandblaster, but I may end up spending that plus what I spent on this. Darn.
