Air in hydraulic lines
Jeff Steed
10-10-2001 07:21:41
I have a Farmall Super MTA with a 3 point hitch. I replaced the hydraulic lines. Now how do I get the stupid air out of the system???
Jeff
10-12-2001 17:06:22
 Re: Air in hydraulic lines in reply to Jeff Steed, 10-10-2001 07:21:41
Thanks guys. I put oil in but it just wasn't enough. I added more and it works just fine now. It sure was frustrating. Thanks again
John ('48 Cub, Ohio)
10-11-2001 03:20:13
When I cracked my Cub this spring (and reassembled it) I had to cycle it 12-20 times to get all the air out. About halfway through I stopped and added more fluid. If you haven't drained it all out like I did, you shouldn't have to add much.
JohnP
Aaron
10-10-2001 17:21:38
If you cycle it a few times, you should eventually get he air worked out. Just keep checking the level to make sure you don't run it dry.
Aaron
