Yazoo YR 60
mailman
10-09-2001 16:15:37
lookin for manual for yazoo YR60,repair,owner,part's
25-30 yr's old been told
Ken
04-27-2002 19:06:58
 Re: yazoo YR 60 in reply to mailman, 10-09-2001 16:15:37
Let me know if you get one and I'll buy a copy from you. I have the same mower.
Ken
Ron Howell
05-04-2002 21:14:13
 Re: Re: yazoo YR 60 in reply to Ken, 04-27-2002 19:06:58
Hi Ken, i can supply the manual for the yr 60 so if you would like to email me i can help you out there. Also i have a large quanity of old yazoo parts and would be happy to send you any information you need if you needed parts.
Hank Daum
07-01-2004 20:39:38
 Re: Re: Re: yazoo YR 60 in reply to Ron Howell, 05-04-2002 21:14:13
I am searching for a YR60, or YR 48, or YR76 Yazoo mower. I'm in Madison Wisconsin, and willing to do some traveling. Anyone out there have one that is gathering dust which they want to send to a nice home where it will once again sense it has a reason for existing?
[email protected]
Steven
05-25-2002 10:32:28
Hi, i found this forum through a google.com serach, we have a yazoo and we have lost the manuel for it and our clutches need ajusted.
if you could Email me with any information on how to do this cause we think we know but we want to be sure so we dont mess anything up, or if you know of a place were we could buy a manuel for it.
I would greatly appreciate it. thanks
steven
Ron Howell
05-27-2002 05:27:15
 Re: Re: Re: Re: yazoo YR 60 in reply to Steven, 05-25-2002 10:32:28
Hey Steven, WHATEVER you do don't drop that clutch spring down the tranny or kiss some 8-12 hours goodbye splitting the box apart etc etc. My trick is to stuff cloth/rag down both sides just while i'm making the adjustment. What i'll do is scan the info you require out of one of my manuals & then try to email it to you. Just give me a couple of days to do this. Cheers Ron
P.S. Tools to use are 2 flat head screwdrivers with one screwdriver turned 90 degrees at the bottom so it makes a hook to lift the spring while the other screwdriver puts pressure on the back of the spring so it doesn't pop out.
Steve
06-05-2002 09:55:34
 Re: Re: Re: Re: Re: yazoo YR 60 in reply to Ron Howell, 05-27-2002 05:27:15
hey sorry i'm back my internet connection dropped on me for the past week :( ok thanks that will be very helpful, we haven ot touched it cause we dont know what were doing just yet lol. ok whats your email address so i knwo what to look for? well thanks agian
steve
Ron
06-23-2002 21:45:59
 Re: Re: Re: Re: Re: Re: yazoo YR 60 in reply to Steve, 06-05-2002 09:55:34
Email address is [email protected] Hope u got it adjusted alright. cheers Ron
Steven
06-23-2002 23:51:06
 Re: Re: Re: Re: Re: Re: Re: yazoo YR 60 in reply to Ron, 06-23-2002 21:45:59
hey i jsut went throuhg my emial again and looked and didnt see your email addy, if oyu sent it already when did oyu put in subject and when, my internet when down the other day again ( curses at computer) so my hotmial account was packed so if it got sent back to you send it again thanks
steven
Ron
06-26-2002 15:59:54
 Re: Re: Re: Re: Re: Re: Re: Re: yazoo YR 60 in reply to Steven, 06-23-2002 23:51:06
1. Make sure clutch lever is in neutral. 2. Remove inspection plate. 3. Rotate the input shaft until the square end of the adjustment lock spring is visible through the inspection hole. 3. Roll the machine slightly until the edge of the forward drive cup is clear of the lock spring. 4. Place the end of one screwdriver under the edge of the lock spring. Using the shifter sleeve as a heel,pry the lock spring up until it clears the notches of the adjustment collar. 5. To tighten the clutch, skip one notch from the end of the adjusting spring, placing the second screwdriver in the second notch of the adjustment collar. This will keep the adjustment collar from moving more than one notch at a time. Move the adjusting collar TOWARD the large end of the lock spring until the spring end will fall into the first notch. Always make the adjustment in one notch increments, as one notch may be all that is needed. 6. To loosen the clutch, move the adjusting collar AWAY from the large end of the lock spring. 7.Replace inspection plate
Steven Duncan
05-17-2002 09:05:23
Ron,
What kind of parts do you have? What state are you in? We have lots of old Yazoo's for our business and are looking for parts.
Ron
06-26-2002 16:14:45
 Re: Re: Re: Re: yazoo YR 60 in reply to Steven Duncan, 05-17-2002 09:05:23
Hey Steven, I'm in Australia and i have most parts for the older yazoo,s mechanical box type and early hydro. With the price of spares rising some 300 % over the last few years thanks to the yazoo/husky merger i am very competitive on pricing even being this far away. If you want to take this any further message me. cheers Ron
