Another Air Compressor Post
Jason
10-05-2001 17:51:21
I need to buy an air compressor for painting and sandblasting. I am considering a Campbell Hausfeld 6.5 hp, 60 gallon upright model. This model is 240 volts. Does this mean that it cannot be plugged into a regular home electrical outlet? If not, then what do I need to do to be able to operate it? Your comments are appreciated.
John Ne.
10-09-2001 06:26:23
 Re: Another Air Compressor Post in reply to Jason, 10-05-2001 17:51:21
I'm confused, you want to run a compressor to power your sandblaster, and plug it in at your home? If you're married you won't have a happy home if that sandblaster is less than 100 feet from the house! Most guys do that far away from their shop. John Ne.
LarryG
10-17-2001 05:06:07
 Re: Re: Another Air Compressor Post in reply to John Ne., 10-09-2001 06:26:23
I guess you've just made me appreciate my wife a little more - I installed my 6.5 hp, 80 gal unit in the 2-car garage under the living room (my side, of course!) The whole house shakes. The only time she complained was the first time she was home alone and I forgot to shut off the pressure activated switch and the unit started up for no apparent reason. She didn't know what the devil it was since I wasn't home. I'm lucky she didn't have a heart attack.. Now it's referred to as that "thing in the garage"
Alan Y.
10-07-2001 01:24:25
Sandblasting can require a lot of air. Make sure the output of the compressor more than matches the consumption of the sandblaster you plan to use. A 110 volts compressor may be marginal to inadequate for haavy sandblasting.
ted
10-06-2001 11:30:45
No, this compressor will not operate on your standard 110 volt plug. It will require 240 volts and may have a cord simmilar to an elect. dryer. You will need to run a line to it. It may have to be hardwired in if there isn't a cord. Another question is to be sure you have adaquate power going to your house-shed-garage or whatever it's going into.
Some smaller compressors can be wired to run on 110 or 220.
