Tecumseh lawn mower engine
Ken
10-03-2001 19:18:07
I have a craftsman lawn mower with the 6.75 tecumseh engine that I took in for what I would call routine service. It has slowly been taking more priming and several tries to get started and keep running. It fires immediately and then dies like starved for fuel. Anyway the repair shop calls up and tells me I have a burnt exhaust seat and need a new engine block! Is this guy cracked in the head or is this really what causes the problem. Any Tecumseh experts out there?
Thanks in advance!
Howard Hill
08-08-2005 06:58:00
 Re: Tecumseh lawn mower engine in reply to Ken, 10-03-2001 19:18:07
Looking for TVM195 150091J short block
Trapper
10-08-2001 07:24:22
Classic Tecumseh problem!
Take the fuel bowl cup off the bottom of the carb.
There is a pin hole used to balance barometric air pressure on the diaphram.
If that hole gets plugged (which happens often) the engine gets fuel starved, as it's pulling against a vacuum.
The hole is small, so use a bristle from a wire brush to clean it out.
Peter S
10-05-2001 12:01:53
I often find complete factory spare parts kits by the side of the road. Keep looking, you'll find one soon.
Ken
10-05-2001 17:13:21
 Re: Re: Tecumseh lawn mower engine in reply to Peter S, 10-05-2001 12:01:53
Took engine cover off today, seats looked fine, so I ground the valve stems down a little and reassembled just like I do with all my Briggs motors. Started on the second pull and mowed the whole lawn. Sigh,, I guess if you want it done right , you gotta do it all yourself!
Jim K
10-04-2001 17:39:39
Sounds fishy to me I believe most valve seats are replaceable I'd get a second opinion if it we're me.
