Diesel Knocking
Brian
10-01-2001 06:11:56
I have an IH 706 that has taken to knocking quite loudly. I am a novice at diesel repair, so I am looking for some advice. What could be causing the knock? The tractor still has ample power and is running pretty well, just knocking loud. It sounds like a metal on metal knock, and I don't think its a valve. Any advice would be appreciated.
jim
10-06-2001 16:43:38
 Re: Diesel Knocking in reply to Brian, 10-01-2001 06:11:56
it maybe piston knock what you can do is try looseing injector line while engine is running and it should tell which cyl. it is because it will soften knock noise. that will tell which cyl it is.
george md
10-22-2001 21:59:59
 Re: Re: Diesel Knocking in reply to jim , 10-06-2001 16:43:38
remove oil filter , cut apart , squeeze dry.
see if it contains metal, if so check with magnet,if it sticks it is likely to be bearing,
if it doesn't stick ,probably piston.
