Advice on Purchase of Air Compressor
Ken R.
02-26-1998 17:55:03
An air compressor is an essential tool in the restoration of an old tractor; hence it is important that one be selected that can do the job. The more I talk with sales people and read articles, the more confusing the process gets. In addition, I prefer not to pay an "arm and leg" for one as it will probably not get continual or heavy use. On the other hand, I don't want to burn it up because it lacks durability.
I plan to use the following tools with a compressor: - Paint gun - quart size - to prime and paint all but sheet metal - Dual action sander - 6" - Grinder, right angle - Rachet - Sand blaster - possibly a quart sized unit for for small parts
Recently, I looked at a Coleman oil-free, single cylinder, 5hp, 20 gal model. It is wired for 120 convertible to 240. It puts out 9.1 cfm @ 40 lbs. and 7.3 cfm @ 90 lbs. 120 lbs. sq. inch max. working pressure. The price was right but I'm unsure about the specs.
Any suggestions will be appreciated.
Ken
Paul D
03-12-1998 18:21:17
 Re: Advice on Purchase of Air Compressor in reply to Ken R., 02-26-1998 17:55:03
Ken
I have had a two horse for 15 years and it is still running strong. I have done about everything with it. some advise make sure you get a 220 motor, some of the higher hp 120 motors are a joke, no power. get a oil one, belt driven. The most important thing to keep in mind is for most things you want a large tank 2 hp should be fine, The idea is not to run the compressor all the time, but to fill the tank and let the air inside cool, cooler the air the less water it will hold. A small compressor will run all the time if you are doing sand blasting, resulting in hot air cooling in the lines and causing lots of water mixed with the sand be sure you use at least one water trap.
good luck Paul
michael Kellar, Sr.
03-10-1998 18:56:38
: An air compressor is an essential tool in the restoration of an old tractor; hence it is important that one be selected that can do the job. The more I talk with sales people and read articles, the more confusing the process gets. In addition, I prefer not to pay an "arm and leg" for one as it will probably not get continual or heavy use. On the other hand, I don't want to burn it up because it lacks durability.
: I plan to use the following tools with a compressor:
: - Paint gun - quart size - to prime and paint : all but sheet metal
: - Dual action sander - 6"
: - Grinder, right angle
: - Rachet
: - Sand blaster - possibly a quart sized unit for
: for small parts
: Recently, I looked at a Coleman oil-free, single cylinder, 5hp, 20 gal model. It is wired for 120 convertible to 240. It puts out 9.1 cfm @ 40 lbs. and 7.3 cfm @ 90 lbs. 120 lbs. sq. inch max. working pressure. The price was right but I'm unsure about the specs.
: Any suggestions will be appreciated.
: Ken : :
If anybody needs Air Compressor I have a LeRoi 50 horsepower 200 C.F.M. , It is 440 3 phase, Idea for any repair shop, comes with 150 Vertical Tank and all Pipeing , Original cost excess of $17,000. will Take $ 5200.00
Garry G
02-28-1998 16:29:25
Ken I got a sears version of what you described and
I just finished an NAA restoratation with no complaints.
I was worried that I might have to go to 240 to get the ininterrupted air supply for painting but
No problems. I used the compressor to drive the
paint guns, a 'DA' sander, general cleaning and
grunge work. I think I popped the breaker one
time.
I was glad I bought a couple of in-line filters
for moisture. It seemed to help out.
Good Luck
JerryU
02-26-1998 18:09:33
first rule - get as much as your pocket book can afford.
I have a small 12 gallon oiless. Has been chugging for about 4 years. Mainly use it for impact tools, ratchets, etx.
Is a little small for spray painting or sandblasting, but I was limited to 115v 15 amp service.
I had doubts about the oiless, but as I said its still going and for what I paid for it if the pump shells out, it doesn't owe me anything.
You are on the right track with tank - bigger the better.
Obviously, if you can afford it a large verticle with a cast iron pump will last forever, ther are some good deals on these - I've seen them at Tractor Supply.
You also might want to check out Harbor Freight - they have a lot of different compressors and shipping is free over $50 order. www.harborfreight.com
Hope this helps.
JerryU
dave
02-27-1998 05:06:52
 Re: Re: Advice on Purchase of Air Compressor in reply to JerryU, 02-26-1998 18:09:33
: first rule - get as much as your pocket book can afford.
: I have a small 12 gallon oiless. Has been chugging for about 4 years. Mainly use it for impact tools, ratchets, etx.
: Is a little small for spray painting or sandblasting, but I was limited to 115v 15 amp service.
: I had doubts about the oiless, but as I said its still going and for what I paid for it if the pump shells out, it doesn't owe me anything.
: You are on the right track with tank - bigger the better.
: Obviously, if you can afford it a large verticle with a cast iron pump will last forever, ther are some good deals on these - I've seen them at Tractor Supply.
: You also might want to check out Harbor Freight - they have a lot of different compressors and shipping is free over $50 order. www.harborfreight.com
: Hope this helps.
: JerryU
Your right Jerry ! those oiless compressers are ideal for us "Joe homeowners" A freind has one (Sears) , had 5 years, still going strong, I'm next !, hope to buy one in the spring. As far as a aux. tank, I use an old 40gal. hot water heater tank, if you use one, make sure it's in good shape and be sure to test it ! Just fill it 99% with water then fill with air, this way if it falls you'll only have a small volume of air at 150psi ! instead of a 40 gal. 150psi bomb !!
later dave
JerryU
02-27-1998 13:09:49
 Re: Re: Re: Advice on Purchase of Air Compressor in reply to dave, 02-27-1998 05:06:52
I have to very strongly advise against using a hot water heater for a tank. This is very very dangerous. They are only rated for a nominal operating pressure of around 50 psi or so.
I would not use anything that does not have an ASTM certification on it. Secondly, never use a tank without a relief valve on it. These are receipes for getting hurt.
JerryU
dave
02-27-1998 15:28:06
 Re: Re: Re: Re: Advice on Purchase of Air Compressor in reply to JerryU, 02-27-1998 13:09:49
: I have to very strongly advise against using a hot water heater for a tank. This is very very dangerous. They are only rated for a nominal operating pressure of around 50 psi or so.
: I would not use anything that does not have an ASTM certification on it. Secondly, never use a tank without a relief valve on it. These are receipes for getting hurt.
: JerryU
JerryU, Your right ! a hot water heater tank is a "POOR" choice !, They are to thin walled to use for an air tank, even with my half-ass test ! It kills me, I've been useing this tank for years !, I've been danceing on a mine field, think I'll remove it from the shop this weekend !!
Bonehead dave, part 2
Jim
02-28-1998 14:49:33
 Re: Re: Re: Re: Re: Advice on Purchase of Air Compressor in reply to dave, 02-27-1998 15:28:06
: : : I have to very strongly advise against using a hot water heater for a tank. This is very very dangerous. They are only rated for a nominal operating pressure of around 50 psi or so.
: : I would not use anything that does not have an ASTM certification on it. Secondly, never use a tank without a relief valve on it. These are receipes for getting hurt.
: : JerryU
: JerryU, Your right ! a hot water heater tank is a : "POOR" choice !, They are to thin walled to use for an air tank, even with my half-ass test ! : It kills me, I've been useing this tank for years !, I've been danceing on a mine field, think I'll remove it from the shop this weekend !!
: Bonehead dave, part 2
The CFM rating of your tools should help you decide how big a compressor to get. I know mine is too small (and old) to run a DA sander. My next one will be oversized. I don't even want to think about "homemade" air tanks!!! Yikes! Good Luck.
Dusty
03-01-1998 13:22:56
 Re: Re: Re: Re: Re: Re: Advice on Purchase of Air Compressor in reply to Jim, 02-28-1998 14:49:33
: : : : : : I have to very strongly advise against using a hot water heater for a tank. This is very very dangerous. They are only rated for a nominal operating pressure of around 50 psi or so.
: : : I would not use anything that does not have an ASTM certification on it. Secondly, never use a tank without a relief valve on it. These are receipes for getting hurt.
: : : JerryU
: : JerryU, Your right ! a hot water heater tank is a : : "POOR" choice !, They are to thin walled to use for an air tank, even with my half-ass test ! : : It kills me, I've been useing this tank for years !, I've been danceing on a mine field, think I'll remove it from the shop this weekend !!
: : Bonehead dave, part 2
: The CFM rating of your tools should help you decide how big a compressor to get. I know mine is too small (and old) to run a DA sander. My next one will be oversized. I don't even want to think about "homemade" air tanks!!! Yikes! Good Luck.
Any motor rated at 2 hp. and up should be hooked 230 volt.
Dusty
