Welding Aluminum
Joe
09-27-2001 13:36:38
I have some 6061 aluminum that I need to weld. It is 3/4 to 1" thick. I'm concerned about the stregth of the welds. What is the best methold to use?
Thanks
Joe
morris John
09-27-2001 14:03:57
 Re: Welding Aluminum in reply to Joe, 09-27-2001 13:36:38
Best method would be tig, run you machine well different for people but 70% just using the tungsten start by making 2 L bracket just enough to hold the alumin in place start of by tacking the corners just by tacking metal to metal. then if its straight and lined up right. I would try welding the seam all the way down. If you think the pentration is good but couged in then run a cover pass with filler rod
