Need advice on an air compressor....
John
09-24-2001 15:07:40
I want to get an air compressor, but I don't want one of those "oil-free" deals, I want one that is lubricated. I am not concerned about the tank size, I just want it to be on wheels and also plug right into the regular wall socket (110?). Any info on what company sells these and how to contact/find them asap is appreciated!!
mcj
09-25-2001 18:38:46
 Re: Need advice on an air compressor.... in reply to John, 09-24-2001 15:07:40
Oil free compressors are also good if you want to spray paint. Oil/water separators don't always get all the contaminants out, and some oil will invariably end up in your paint job causing fisheyes.
Greaseman
09-25-2001 15:26:51
I usually go to Sears, or Loew's. I have an "oil free" machine but will be changing to an pressure sump-oil unit. Reason: NOISE LEVELS ARE VERY HIGH. I am going to purchase a large machine which should be able to pump out 12CFM at 90 PSI. This in conjunction with the old unit I will be acquiring shortly should be able to pump out all the air I need and then some.
Branden
09-25-2001 10:17:37
I have a 5 hp, oil-free, DeVillbis air compressor with a 25 gallon tank, that has been fired up DAILY for the past 3 years. It has been trouble free and mess-free. I wasn't too hot on the idea of an oil-free one either, but price wise, I got this one. I don't regret it either.
Branden
John in MA
09-24-2001 16:16:27
Zillions of companies sell oil-lubed compressors in your range. Walk into Home Depot or other store like that. They'll have a good selection. Most are 220V, but there are less powerful ones that are 120V.
Good luck.
Dean
09-24-2001 15:31:07
You might want to figure out the capacity (CFM and pressure) you need before you buy one. A 115V/15A unit might be OK for hobby use but I wouldn't want to be trying to sandblast with one!
