Crazy briggs
mart
09-24-2001 12:10:54
My mower does wierd things. Mostly it starts ok and i use it most of the day then i come to start it and it starts at low revs and refuses to go to full throttle without stalling.It does this several times and then it wont run any more. Come back to it another day and it runs ok, misfirng a little sometimes and sometimes running perfectly then when it feels like it goes back to the old routine again. Gave it new plug, filter, gas cap and had carb cleaned.
Gene Davis
09-24-2001 18:56:09
 Re: crazy briggs in reply to mart, 09-24-2001 12:10:54
You may want to look into the valve clearences. Also if it has regular ignition, check the point,and coil air gap. Also while you are that close check the flywheel key.
